| » Injector hose leaks when water pressure is low |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: La512 Brand: Maytag Age: More than 10 years
After taking the machine apart because of a constant leak and putting it back together several times(thought the problem was fixed) I discovered by chance that the sleeve (part#ap249047) midway in the injector hose, fills up with water and overflows when someone turns on a tap or flushes a toilet during the fill cycle. It appears the lower the water pressure to the machine the quicker the sleeve fills with water(and overflows). This has only started last week . never had the problem before. any reason for this, and if I replace the nozzle and the valve, will this cure the problem?
What is the purpose of this injector hose? Why not put a solid closed connector between the two hoses? ED |
| Display Modes | |
| gas pressure adjusment | tuta68 | Oven Repair (including Ranges and Cooktops) | 1 | 08-09-2007 05:50 PM |
| Replacing Drain Hose on Bosch Dishwasher | Lorenzo | Dishwasher Repair | 2 | 08-07-2007 06:24 AM |
| Indoor water dispenser hose replacement | JOHN BIERMAN | Refrigerator & Freezer Repair | 1 | 08-01-2007 09:45 PM |
| frig. leaks from filter | p1rat | Refrigerator & Freezer Repair | 0 | 08-01-2007 08:04 AM |
| refridgerator leaks water from inside | kmape | Refrigerator & Freezer Repair | 1 | 07-30-2007 10:40 AM |
