Discuss
Pump never empties tub; no spin cycle...
 in
Washer Repair
Hello All! Hope the experts here can solve this one: Our Whirlpool LPR6244AN0 'freezes' at the point the pump should
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Pump never empties tub; no spin cycle...
LinkBack (1) Thread Tools Search this Thread Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-21-2008, 10:59 AM
ApplianceLou ApplianceLou is offline
Junior Member
ApplianceLou is on a distinguished road
Default Pump never empties tub; no spin cycle...
Model Number: LPR6244AN0   Brand: Whirlpool   Age: 5 - 10 years
Hello All!
Our Whirlpool LPR6244AN0 'freezes' at the point the pump should be emptying the tub.
Using (for example) the gentle cycle, the tub fills correctly, wash cycle starts and advances correctly, then... nothing.
Have a feeling the timer assembly may be OK, as it advances correctly up to this point (and I can hear the timer motor running right through to the 'dead' spot)
I don't hear any activation of the pump, and there are no grinding, spinning or other unhappy noises being made.
Is it the motor start switch which would control activation of the pump, even though the motor runs great for agitation (is it the same motor?)?
Ideas? Thanks in advance. Lou
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 12:19 PM
fyxer fyxer is offline
Junior Member
fyxer is on a distinguished road
Default no spin cycle
there is a lid switch that stop the machine when someone open the lid,when machine is spinning it can be dangerous if someome stuck their hand inside, if this switch is broken the machine will not spin,check also to make sure the lid switch actuator is not broken or missing, the actuator is usually a small piece of plactic attach to the lid when you open the lid it open the switch,and close the switch when the lid is closed.
  #3 (permalink)
Old 01-21-2008, 01:04 PM
Junior Member
Default Thanks, Fyxer,
for your response. Wow, yes, that makes perfect sense - because the 'wash' cycle would work even with the lid up, right? ...as it does.
As I recall, the pump and spin functions require the lid down - am I correct?
Is this switch a simple two-pole assembly? IE, can I simply jumper it to test the hypothesis?
Totally Correct! And thank you for your diagnosis. The switch works only intermittently, causing the problem. Suspect I may need to clean or replace it, but in the meantime, a little extra pressure when closing the lid does the trick.
Thanks for your help. - Lou
  #4 (permalink)
Old 01-22-2008, 01:10 AM
subcultures10 subcultures10 is offline
Junior Member
subcultures10 is on a distinguished road
Default
Replace your lid switch assy. It's Not hard, but isnt easy..I give it a 3 out of 10 on the hard scale.
A load may have gotten out of balance and broke the lid shaft/paddle. Or could have just broke on its on
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/4653-pump-never-empties-tub-no-spin-cycle.html
Posted By For Type Date
Digg / Tech Industry News / Upcoming This thread Refback 01-21-2008 12:55 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool LA7680XT fills, empties, but doesn't agitate or spin jcoronat Washer Repair 6 01-20-2008 04:42 AM
maytag will not spin agitate or pump drembo Washer Repair 7 12-25-2007 03:37 AM
pump out but no spin ericand Washer Repair 2 12-05-2007 03:20 AM
Pump Drains Tub But No Spin Cycle matt b Washer Repair 2 09-26-2007 05:51 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
