Discuss
Kenmore 70 Series Washer Stalls Just Before Draining
 in
Washer Repair
My washer just started to stall when it reaches the point where it should drain the tub after the rinse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 70 Series Washer Stalls Just Before Draining
  #1 (permalink)
Old 04-11-2012, 10:49 PM
Junior Member
maudie is on a distinguished road
Default Kenmore 70 Series Washer Stalls Just Before Draining
Model Number: 110.82873100   Brand: Kenmore   Age: More than 10 years
My washer just started to stall when it reaches the point where it should drain the tub after the rinse cycle. That is, the dial advances to the asterisk marker (rinse & spin) and the tub fills. There's some agitation and the dial starts to advance to the diamond marker (spin only). There's a click sound which I assume is the point where the tub should drain. After that, nothing happens. I let the washer sit for a half hour without the dial advancing or the tub draining.
However, if I give the washer a healthy whack on the same side as the dial, the tub starts draining. and most times completes through the spin only cycle. Other times, I give the washer a whack, it drains for a few seconds, then stops, I give it another whack, it drains for a few seconds, then stops, and so on. Eventually, the dial advances to a point where the washer drains completely, and continues on through the final spin cycle.
Where do I start diagnosing?
Ads By Google
Related Models
Kenmore 110.83679630  ELECTRIC DRYER
Kenmore 110.84832200  ELECTRIC DRYER
Kenmore 110.84832201  ELECTRIC DRYER
Kenmore 110.84834200  ELECTRIC DRYER
Kenmore 110.84834201  ELECTRIC DRYER
Kenmore 110.84836200  ELECTRIC DRYER
Kenmore 110.84836201  ELECTRIC DRYER
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Series 90 Washer Not Draining but Does Spin TaquacheDawg Washer Repair 1 03-29-2012 04:56 AM
Kenmore elite stalls and won't spin lawrencealton Washer Repair 0 02-27-2011 02:37 PM
washer stalls with full tub kendallgo Washer Repair 0 02-07-2011 05:39 PM
Kenmore 80 Series drops "lock" from drain to spin; spins while draining FalconFour Washer Repair 3 12-20-2010 06:14 AM
Kendmore Washer 60 Series Will not Spin after draining gabert949 Washer Repair 5 09-08-2009 01:29 PM
