Discuss
Maytag Washer fills then stops
 in
Washer Repair
When I start the washer, it will fill with water, then it will not start the wash cycle. The timer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer fills then stops
  #1 (permalink)
Old 01-21-2008, 09:54 AM
Tazman Tazman is offline
Junior Member
Tazman is on a distinguished road
Unhappy Maytag Washer fills then stops
Model Number: LAT 2914 AAE   Brand: Maytag   Age: More than 10 years
When I start the washer, it will fill with water, then it will not start the wash cycle. The timer will continue to go and will go to off, but the wash and spin never start. If I slowly move the inner dial, the wash and or spin cycle sometimes will start. My guess is that it is the timer control but I would like another opinion before I get the part which is part #22001025. Thanks for any help you can give me.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 06:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the motor overload for continuity (across the W & BK terminals).
If it's open - the motor has to be replaced.
Check for continuity across the Y And BU motor terminals.
Check for 120V between the Y and BU wires coming to the motor when the timer calls for agitation.
If there is no power, check the wires from the timer to the motor and if there is nothing wrong, then the timer has to be replaced.
- The part number for the motor is AP3720974
- The part number for the timer is AP249818
Here are the break down diagrams for the Maytag washer Model LAT2914AAE
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-22-2008, 01:04 AM
subcultures10 subcultures10 is offline
Junior Member
subcultures10 is on a distinguished road
Default
check your lid switch as well. But if your moving the timer sometimes and getting it to start washing or spinning sounds like one of the contacts in the timer has a bad spot on them and getting caught.
  #4 (permalink)
Old 01-22-2008, 08:18 AM
Junior Member
Default
As I stated in the first note, the wash and spin cycle will work in I move the inner dial and the motor will run through both cycles. Will this elimate the motor overload for continuity option ?? The lid switch works as I have checked that when I could get the wash or spin cycle working by lifting and closing the lid. Does this reply indicate the timer control being bad ??? I have also run the different water levels (small, medium and large) and that is working as the levels have been correct.......Thanks for your help and waiting for your reply before I order the timer control..
  #5 (permalink)
Old 01-23-2008, 01:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In such situation looks like the problem is the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fills and stops metten2@verizon.net Washer Repair 9 01-08-2008 02:57 PM
Maytag Dryer Stops after 30 seconds austein Dryer Repair 4 01-03-2008 09:28 PM
Maytag Washer fills only Mark767 Washer Repair 1 01-02-2008 03:17 AM
water fills and stops intermittently worldtravelert Washer Repair 0 12-08-2007 10:50 AM
maytag washer stops after humming noise mulskin Washer Repair 0 12-01-2007 11:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
