My washer is leaking. It is likely an easy fix because the (spring or clamp) came off. I have tried several times to put it back in place but washer still leaking a lot of water!!!! The bellow does not look worn out to me. washer is about 2 years old. Can you tell me how to attach the spring or Clamp part# 8540107 to the bellow part # w10189283?
Thank you,:confused: Kps0999
