The spin cycle won't spin automatically on all 3 catagory cycles, but will spin manually. What is the problem?
Can you explain what you mean when you say it will spin manually. Does this mean you have to move the timer, or in some way manually start the machine spinning?
Also, when it does start spinning does it finish the cycle correctly and are there any other problems/symptoms?
Originally Posted by: sidfink43 Can you explain what you mean when you say it will spin manually. Does this mean you have to move the timer, or in some way manually start the machine spinning?
Thanks When the timer reaches spin the machine stops. You can rest set to spin & the machine will spin out & complete the washing cycle.
