| » Estate Top Loading Washer Grinding spin cycle (Model year 2000?) |
Model Number: TAWS700EQ2 Brand: Estate Age: 5 - 10 years
Hello gentlemen!
This washer has served us well and except for a bad lid switch and water level control knob that once flooded our downstairs...make that twice....we have not had any issues. Now: Few weeks ago starts making high pitched scratching/grinding sound while spinning but not load enough to cause too much concern. Yesterday while entering spin cycle, the tub spins fine but starts a more distinct grinding noise. the agitator attempt to turn but starts loud clicking noise. Checked the dogs and replaced but the problem persists. Took of the housing and checked the coupling and it's fine. Clutch turns along with motor. Grinding noise seems to be coming from gear case housing but I am only 90% sure. What do you pros think? I removed the entire agitator and put it in spin cycle and recorded the sound of the grinding. Have a listen, please. File is attached. Thanks! Adam Ads By Google Related Models Last edited by fareall : 08-30-2009 at 06:59 PM. |
Remove pump and motor, turn coupler clockwise till the clutch housing starts to turn. If you feal something grinding at certain periods while spinning, you probably have a bad tranny. Pull it out and do the same test, if still present, you have missing teeth in the tranny spin gear, replace tranny, or install a new nylon gear and pinion gear available on this parts site.
Tranny part # AP3096209
__________________
- Last edited by richappy : 08-31-2009 at 02:32 AM. |
| Display Modes | |
| Whirlpool washer makes grinding noise on spin cycle | reescup4 | Washer Repair | 5 | 09-03-2009 02:05 PM |
| Maytag top loading washer leaking in spin cycle from bottom | kleve | Washer Repair | 3 | 07-23-2009 11:12 AM |
| Maytag LA8650 Washer - Grinding/Scraping/Rattle Noise During Spin Cycle | Carol2 | Washer Repair | 11 | 04-02-2009 03:33 PM |
| front loading washer off balance in spin cycle | bruciemom | Washer Repair | 4 | 12-10-2008 10:14 AM |
| ge washer makes lound grinding noise is spin cycle. | tater | Washer Repair | 7 | 03-24-2008 05:57 PM |
