fill with water, drum starts turning, then ear squeaking noise after 30 seconds, then smell belt or something smoking.
Originally Posted by: bob behling fill with water, drum starts turning, then ear squeaking noise after 30 seconds, then smell belt or something smoking. washer is 25 years old.
Hi Bob,
It would be helpful if you posted the model number for us.
Sounds like you may want to check the belt or belts depending on your model.
Originally Posted by: bob behling Originally Posted by: bob behling fill with water, drum starts turning, then ear squeaking noise after 30 seconds, then smell belt or something smoking. washer is 25 years old and has served us well. model # isw LA612 SERIES 04 SERIAL #071597T or 7F
perhaps a bearing or roller is ceased? is this possible?
