| » Tub Bearing Kit |
Model Number: LAT9420AAE Brand: Maytag Age: 5 - 10 years
I'm installing a tub bearing kit. It's all done exceot i'm having problems removing one piece from the tub bearing kit... Its the 3 inch metal tube... Do you have any advice on how to slip that part off of the transmission?
![]() The new part is being held up next to wear it belongs... The old one does not seem to want to come off... We have sprayed it with WD40,, Does anybody have any other suggestions? Ads By Google Related Models |
Hi.
Try to hammer it gently around, use the channel locks to turn it side to side. The heavy artillery would be using the old fashion chisel. Be very careful not to damage the transmission. Locate the vertical grove and chisel along it. Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Tried the hammer and vise grips,, Not much luck... Went to the "heavy artillery" with my friend's grinder, and a very thin wheel... Slow strokes with little pressure did the job! (Didnt have a chisel)... Once I had a small groove cut in,, I put a common screwdriver, and twisted resulting in the piece breaking rather easily...
Thank you for your quick reply. I was thinking of trying something like this but was conserned with damaging something. Also I wanted to hear it come from an expert first.... Also better than just leaving the old one on there..(I was thinking of that too,,lol) ![]() Last edited by WAlicea : 04-07-2012 at 02:51 PM. Reason: clarity |
You are very welcome.
Simon. PS. Good photography.
__________________
| Display Modes | |
| Bearing | Silbaugh | Dryer Repair | 0 | 10-12-2011 11:47 AM |
| bad bearing | creteman4 | Washer Repair | 1 | 07-30-2011 09:05 AM |
| Bad tub bearing | richappy | Washer Repair | 3 | 08-12-2009 08:38 AM |
| bearing kit | the pit | Washer Repair | 2 | 07-15-2009 08:53 PM |
| Bearing | DANALVIN | Washer Repair | 0 | 12-27-2008 10:52 AM |
