Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer won't advance past wash and 1st drain cycle (http://forum.appliancepartspros.com/washer-repair/460973-washer-wont-advance-past-wash-1st-drain-cycle.html)
kcsmam 04-06-2012 11:34 AM
My front loader won't advance past 1st wash cycle. Have just replaced timer no change on all wash cycles. It is though what ever is supposed to tell the washer to fill for rinse is not happening. Is ther a water level switch? or control board issue. Any help appreciated.
Simon / APP Team 04-06-2012 12:27 PM
Hi.
Does the washer work if you select "cold water" wash?
Post the results.
Simon.
kcsmam 04-06-2012 12:33 PM
no????? Bad hose? weird since they are brand new. They are the anti flood type hoses.
Simon / APP Team 04-06-2012 05:02 PM
Hi.
Those are famous for stopping the water when ever they want to.
Check the cold water hose.
Replace them with stainless still ones.
Post the results.
Simon.
kcsmam 04-07-2012 02:06 PM
The solution
The "flood safe" washer hoses sold at the big box stores were the culprit. I verified that there was no water flowing from the cold hose and then I disconnected it from the tap and that resets the valve in these hoses. One of the keys to this hose is that you need to s l o w l y turn on the supply or the "valve" thinks it has a blown hose and shuts the water off. Thanks for the help.
Simon / APP Team 04-09-2012 05:17 PM
You are most welcome.
Simon.
