Discuss
tub wobbles and oil found inside machine on bottom plate
 in
Washer Repair
the tub wobbles and oil was found inside washer on bottom plate Related Models Maytag  A612  WASHER-TOP LOADING Maytag  A612S
Appliance Repair Forum > Appliance Repair Help > Washer Repair » tub wobbles and oil found inside machine on bottom plate
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-28-2009, 07:15 PM
Junior Member
b.gale is on a distinguished road
Default tub wobbles and oil found inside machine on bottom plate
Model Number: a612   Brand: Maytag   Age: More than 10 years
Related Models
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
Maytag A8420 WASHER-TOP LOADING
Maytag A8440 WASHER-TOP LOADING
Maytag A8500 WASHER-TOP LOADING
Maytag A8520 WASHER-TOP LOADING
Maytag A8600 WASHER-TOP LOADING
Admiral A8610PA SURFACE UNIT- ELE
Admiral A8610PS SURFACE UNIT- ELE
Admiral A8610PV SURFACE UNIT- ELE
Maytag A8640 WASHER-TOP LOADING
Maytag A8650 WASHER-TOP LOADING
Admiral A8670PB SURFACE UNIT- ELE
Admiral A8670PV SURFACE UNIT- ELE
Admiral A86LW-1-R SURFACE UNIT- ELE
Maytag A8700 WASHER-TOP LOADING
Admiral A8720PA SURFACE UNIT- ELE
Admiral A8720PW SURFACE UNIT- ELE
Maytag A8740 WASHER-TOP LOADING
Maytag A8800 WASHER-TOP LOADING
Maytag A882 WASHER-TOP LOADING
Maytag A8820 WASHER-TOP LOADING
Maytag A883 WASHER-TOP LOADING
Maytag A884 WASHER-TOP LOADING
Maytag A8840 WASHER-TOP LOADING
Admiral A88FK-1 SURFACE UNIT- ELE
Admiral A88FK-2-R SURFACE UNIT- ELE
Admiral A88FK-6-R SURFACE UNIT- ELE
Admiral A88FN-2-R SURFACE UNIT- ELE
Admiral A88FN-2R SURFACE UNIT- ELE
Admiral A88LK-6-R SURFACE UNIT- ELE
Admiral A88LN-6-R SURFACE UNIT- ELE
Admiral A89L-4-R SURFACE UNIT- ELE
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A8RXCGFXS00 REFRIGERATOR
Maytag A8RXCGFXS01 REFRIGERATOR
Maytag A8RXCGFXW00 REFRIGERATOR
Maytag A8RXCGFXW01 REFRIGERATOR
Maytag A8RXNGFXD00 REFRIGERATOR
Maytag A8RXNGMWB00 REFRIGERATOR
Maytag A8RXNGMWB01 REFRIGERATOR
Maytag A8RXNGMWD00 REFRIGERATOR
  #2 (permalink)
Old 08-29-2009, 04:14 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Probably a bad tub seal and bearing. You can get repair info at web site www.applianceaid.com
Parts needed seal kit AP244279, panner wrench AP3538707 and bearing kit AP253016
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Wont Heat And Found Green Cable Laying Inside Of Unit laurieallthumbs Dryer Repair 1 01-01-2010 05:15 AM
Oven bottom (plate on underside) jim nichols Oven Repair (including Ranges and Cooktops) 3 08-27-2009 09:22 PM
Found repaired part inside a new purchase product, after 4 years benik9 Washer Repair 1 07-30-2009 04:14 PM
thin oil line found at basin bottom JGP Washer Repair 4 01-30-2008 01:14 AM
stainless plate inside tub bnablaze Dryer Repair 0 11-09-2007 10:46 AM
