Discuss
E03 error on Candy ACS 1040
 in
Washer Repair
E03 error on Candy ACS 1040 said "no water evacuation from a drum" 1) all tubes were checked - no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » E03 error on Candy ACS 1040
  #1 (permalink)
Old 08-28-2009, 12:55 PM
Junior Member
Vvlad is on a distinguished road
Question E03 error on Candy ACS 1040
Model Number: Activa Smart 1040   Brand: -other-   Age: 5 - 10 years
1) all tubes were checked - no garbage in it
2) drain pump was replaced - no effect/ the same E03 error
3) water input was OK, water level sensor (pressostat) works (no gluing in @full chamber@ state)
4) all wires "pressostat-CPU" and "CPU-drain pump" were inspected.
No idea! Will somebody please help to repair this?
Related Models
General Electric ACTK15AH01 Pers elect
General Electric ACTK15AJ01 Pers elect
Amana ACU-514 RANGE- S/C S/I DDRAFT GAS
Amana ACU-516 RANGE- S/C S/I DDRAFT GAS
General Electric ACU06LAM1 Room air conditioner
Whirlpool ACU072PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE1 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE2 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE3 AIR CONDITIONER
Whirlpool ACU072XH0 AIR CONDITIONER
Whirlpool ACU072XJ0 AIR CONDITIONER
Whirlpool ACU072XJ1 AIR CONDITIONER
Whirlpool ACU082XA0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XW0 AIR CONDITIONER
Whirlpool ACU082XX0 Air-conditioner/heat pump
Whirlpool ACU082XX1 Air-conditioner/heat pump
Whirlpool ACU088PP0 AIR CONDITIONER
Whirlpool ACU088PR0 AIR CONDITIONER
Whirlpool ACU088PR1 AIR CONDITIONER
Whirlpool ACU102PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK2 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102XE0 AIR CONDITIONER
Whirlpool ACU102XE1 AIR CONDITIONER
Whirlpool ACU102XE2 AIR CONDITIONER
Whirlpool ACU102XE3 AIR CONDITIONER
Whirlpool ACU102XH0 AIR CONDITIONER
Whirlpool ACU102XJ0 AIR CONDITIONER
Whirlpool ACU102XJ1 AIR CONDITIONER
Whirlpool ACU102XX0 AIR CONDITIONER
Whirlpool ACU102XX1 AIR CONDITIONER
Whirlpool ACU104PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104XH0 AIR CONDITIONER
Whirlpool ACU104XJ0 AIR CONDITIONER
Whirlpool ACU104XJ1 AIR CONDITIONER
Whirlpool ACU108PP0 AIR CONDITIONER
Whirlpool ACU108PR0 AIR CONDITIONER
Whirlpool ACU108PV AIR CONDITIONER
Whirlpool ACU109PP0 AIR CONDITIONER
Whirlpool ACU109PR0 AIR CONDITIONER
Whirlpool ACU114XE0 AIR CONDITIONER
Whirlpool ACU114XE1 AIR CONDITIONER
Whirlpool ACU114XE2 AIR CONDITIONER
Whirlpool ACU114XE3 AIR CONDITIONER
Whirlpool ACU114XE4 AIR CONDITIONER
Whirlpool ACU114XH0 AIR CONDITIONER
Whirlpool ACU124PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK2
Whirlpool ACU124PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PP0 AIR CONDITIONER
Whirlpool ACU124XA0 AIR CONDITIONER
Whirlpool ACU124XD0 AIR CONDITIONER
Whirlpool ACU124XD1 AIR CONDITIONER
Whirlpool ACU124XJ0 AIR CONDITIONER
Whirlpool ACU124XJ1 AIR CONDITIONER
Whirlpool ACU124XX0 AIR CONDITIONER
Whirlpool ACU124XX1 AIR CONDITIONER
Whirlpool ACU129PP0 AIR CONDITIONER
Whirlpool ACU129PR0 AIR CONDITIONER
Whirlpool ACU129PV AIR CONDITIONER
Whirlpool ACV052XG0 AIR CONDITIONER
Whirlpool ACV052XG1 AIR CONDITIONER
Whirlpool ACV052XH0 AIR CONDITIONER
General Electric ACV05LAB1 Room air conditioner
General Electric ACV05LAB2 Room air conditioner
General Electric ACV05LAB3 Room air conditioner
General Electric ACV05LAB4 Room air conditioner
General Electric ACV05LAD1 Room air conditioner
General Electric ACV06LAD1 Room air conditioner
Whirlpool ACV072XG0 AIR CONDITIONER
Whirlpool ACV102XG0 AIR CONDITIONER
Whirlpool ACV102XH0 AIR CONDITIONER
Whirlpool ACV122XH0 AIR CONDITIONER
Whirlpool ACV184XG0 AIR CONDITIONER
Whirlpool ACV184XH0 AIR CONDITIONER
Whirlpool ACV244XG0 AIR CONDITIONER
General Electric ACV24DAT1 Room air conditioner
Whirlpool ACW082XM0 Air-conditioner/heat pump
Whirlpool ACW082XP0 Air-conditioner/heat pump
Whirlpool ACW082XS0 Air-conditioner/heat pump
Whirlpool ACW094XM0 Air-conditioner/heat pump
Whirlpool ACW094XM1 Air-conditioner/heat pump
Whirlpool ACW094XT0 AIR CONDITIONER
Whirlpool ACW104XP0 Air-conditioner/heat pump
Whirlpool ACW114XM0 Air-conditioner/heat pump
Whirlpool ACW144XM0 Air-conditioner/heat pump
Whirlpool ACW144XP0 Air-conditioner/heat pump
Whirlpool ACW144XS0 Air-conditioner/heat pump
Whirlpool ACW864XP0 Air-conditioner/heat pump
Whirlpool ACX082XZ0 Air-conditioner/heat pump
Amana ACX100 RANGE- S/C S/I DDRAFT GAS
Whirlpool AD0122XM1 DEHUMIDIFIER
Whirlpool AD0122XM2 DEHUMIDIFIER
Whirlpool AD0122XM3 DEHUMIDIFIER
Whirlpool AD0152XM0 DEHUMIDIFIER
Whirlpool AD0152XM1 DEHUMIDIFIER
Whirlpool AD0152XM2 DEHUMIDIFIER
Whirlpool AD0152XV0 DEHUMIDIFIER
Whirlpool AD0152XV1 DEHUMIDIFIER
Whirlpool AD0152XV2 DEHUMIDIFIER
Whirlpool AD0202XM0 DEHUMIDIFIER
Whirlpool AD0202XM1 DEHUMIDIFIER
Whirlpool AD0202XM2 DEHUMIDIFIER
Whirlpool AD0202XV0 DEHUMIDIFIER
Whirlpool AD0252XA0 DEHUMIDIFIER
Whirlpool AD0252XA1 DEHUMIDIFIER
Whirlpool AD0252XW0 DEHUMIDIFIER
Whirlpool AD0252XZ0 DEHUMIDIFIER
Whirlpool AD0252XZ1 DEHUMIDIFIER
Whirlpool AD025SG0 DEHUMIDIFIER
Whirlpool AD025SJ0 DEHUMIDIFIER
Whirlpool AD0302XA0 DEHUMIDIFIER
Whirlpool AD0302XA1 DEHUMIDIFIER
Whirlpool AD0302XA2 DEHUMIDIFIER
  #2 (permalink)
Old 08-29-2009, 12:13 PM
Junior Member
Default
Well, today I've measured the AV voltage between C-terminal (blue wire came direct from N-connector of ZW-power filter) and P-terminal (yellow wire or GIALLO on the scheme attached). It was app. 5-8 V AC in "EMPTY drum" and 220 VAC in "above First level". As for S-terminal (red wire run to 1 pin of PN connector on CommandModule 41009801
017938223
41009111 VS C48
ICA INT. 06/10/04
000364479 OP. 28) - voltage changes from 0.08 in "Below second level" into 110 VAC in "Above second level".
If you drop out red wire connector from pressostat, water income doesn't stop i can go over vessel.
The question is "What should I check in Electronic module to ensure the cause of E03 eror hides in it or in pressostat? What should I replace?"
  #3 (permalink)
Old 08-30-2009, 12:34 PM
Junior Member
Default Candy ACS 1040 (31145105 0447 2344)
Thanx for advices. Now I have another pressostat ( 04=06 7670001 12NC 461971077021 65/40 300 ).
It has four(4) pins 11, 12, 14 и 16.
Tell me please if any khows, is it compatible with Candy ACS 1040 (31145105 0447 2344)?
If so, am I write right in my guess of blue wire should be connected into 11,
yellow -to 14 , and red -(from 1 lamelle PN el.module) - at 16?
Can I leave 12 free in air (unfortunately its very hard to fix it with hose from drum, much better join the hose with tube )??
I've noticed, module after 2 lamelle in group of PN goes through 4 resistors into artefact rectangular (may be relay?). What can it be?
Forgive, please my Ignorance, Up now I dealth with biochemical analyzers, X-ray, US, CT and mass-spectrometry.
  #4 (permalink)
Old 09-02-2009, 01:46 PM
Junior Member
Default
Artefact is a capacitor, new relay didn't help - shows the same error 03.
What about scheme for this module? If anybody has , please, share it in vldu at itaec dot ru
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
