| » no cold water on cold/cold cycle |
Model Number: MAV7650AWW Brand: Maytag Age: 5 - 10 years
On cold wash/cold rinse cycle the wash water is hot/warm and the rinse cycle is cold. On all other selections like hot wash/cold rinse there is cold water. Sure appreciate any ideas. thanks
Quote:
Sounds like a problem with either the water temp switch, the water temp board, or possibly( not probable ) the water valve which has a thermistor built into it. Below is a paragraph right out of the Maytag Service Manual, not sure it applies to what you're experiencing or not, considering I don't know what part of the country you live in. I've also included a link to your model with the parts I've mentioned. Within that link you'll find a wiring diagram. The cold water valve is opened for full cold fill. If the incoming water temperature is below approximately 65°F, the hot water valve will open and warm the incoming water. The hot water valve will continue to cycle on and off maintaining optimum cold water temperature until the tub is full. The target water temperature for a cold wash is 70°F to 80°F. Model MAV7650AWW
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| No cold water and no rinse cycle | jhead | Dishwasher Repair | 1 | 02-22-2010 08:03 AM |
| Cold Water only in Soak Cycle | sn8khd28 | Washer Repair | 1 | 01-06-2009 03:36 AM |
| washer won"t run on cold cold water setting | jwh4969 | Washer Repair | 1 | 12-23-2008 06:41 AM |
| no cold water alone coming in .do get hot or warm. so cold must be comin through valv | misterfixall | Washer Repair | 1 | 11-16-2007 12:51 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
