Discuss
washer low cold water flow
 in
Washer Repair
Cold water has low flow, hot water is OK? Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer low cold water flow
  #1 (permalink)
Old 08-27-2009, 07:07 PM
Junior Member
jtwestring is on a distinguished road
Default washer low cold water flow
Brand: Maytag   Age: 5 - 10 years
Ads By Google
  #2 (permalink)
Old 08-28-2009, 07:08 AM
Senior Member
applianceman is on a distinguished road
Default
Make sure you have good flow from the house plumbing. There is a strainer in each of the hoses you may be able to clean out. Also there is a strainer in the valve there the hoses connect you might be able to clean that. Note do not remove the strainer in the valve.
If cleaning the strainers doesn’t fix your problem and you have good water flow replace the water valve.
Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Ensignia washer water flow will not stop getridstuff Washer Repair 1 01-07-2010 04:42 PM
Slowwater flow on Cold side GeneMyrtleBeach Washer Repair 4 11-18-2009 04:25 AM
washer won"t run on cold cold water setting jwh4969 Washer Repair 1 12-23-2008 06:41 AM
Water won't flow into washer gmarkert Washer Repair 1 11-30-2008 04:24 PM
Cold water, hot water flow BEC75 Washer Repair 1 07-02-2008 10:36 PM
