Discuss
Overfilling
 in
Washer Repair
This unit overfills and shuts down, I have replaced a water sensor and the pump, what else could cause this
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Overfilling
  #1 (permalink)
Old 04-03-2012, 03:14 PM
Junior Member
allen.horrex is on a distinguished road
Default Overfilling
Model Number: wfw9150www00   Brand: Maytag   Age: 1 - 5 years
This unit overfills and shuts down, I have replaced a water sensor and the pump, what else could cause this issue?
Ads By Google
Related Models
Whirlpool WFW9200SQ00 Automatic Washer
Whirlpool WFW9200SQ01 Automatic Washer
Whirlpool WFW9200SQ02 Automatic Washer
Whirlpool WFW9200SQ10 Automatic Washer
Whirlpool WFW9200SQA10 Automatic Washer
Whirlpool WFW9200SQA11 Automatic Washer
Whirlpool WFW9400SB00 Automatic Washer
Whirlpool WFW9400SB01 Automatic Washer
Whirlpool WFW9400SBA10 Automatic Washer
Whirlpool WFW9400ST00 Automatic Washer
Whirlpool WFW9400ST01 Automatic Washer
Whirlpool WFW9400STA10 Automatic Washer
Whirlpool WFW9400SU00 Automatic Washer
Whirlpool WFW9400SU01 Automatic Washer
Whirlpool WFW9400SW00 Automatic Washer
Whirlpool WFW9400SW01 Automatic Washer
Whirlpool WFW9400SWA10 Automatic Washer
Whirlpool WFW9400SZ00 Automatic Washer
Whirlpool WFW9400SZ01 Automatic Washer
Whirlpool WFW9400SZA10 Automatic Washer
Whirlpool WFW9600TA00 Automatic Washer
Whirlpool WFW9600TB00 Automatic Washer
Whirlpool WFW9600TC00 Automatic Washer
Whirlpool WFW9600TU00 Automatic Washer
Whirlpool WFW9600TW00 Automatic Washer
Whirlpool WFW9600TZ00 Automatic Washer
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
  #2 (permalink)
Old 04-03-2012, 06:54 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Is" the water sensor " you replaced located on the right top side of the cabinet?
Is the washer stops after the first fill?
What is the water level inside the tub?
Please reply.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-04-2012, 06:55 AM
Junior Member
Default
Water level is more than 1/2 way up the door glass, yes it is first fill, then error code comes up, yes top right side
  #4 (permalink)
Old 04-04-2012, 09:56 AM
Expert
Default
Hi.
Check the pressure switch hose for any cracks or cuts.
Check the connection between the pressure switch and control board. Unplug and plug back the disconnects.
What error code do you get?
Post the results.
Simon.
__________________
  #5 (permalink)
Old 04-04-2012, 10:36 AM
Junior Member
Default
F8E1 - connections and hoses seem fine. What about control panel board?
  #6 (permalink)
Old 04-04-2012, 12:04 PM
Expert
Default
Hi.
Check the continuity between inlet valve VCH7 and CCU DI6.
Next between pressure switch and CCU PR6 cavity.
If harness checks OK - replace the CCU (control board).
The Control board Part number: AP4511768
Here are the breakdown diagrams and Replacement parts for Whirlpool WFW9150WW00 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
  #7 (permalink)
Old 04-06-2012, 05:27 AM
Junior Member
Default
I have continuity between thhose switches, but I did not get which pins should show continuity so all I know is when I touch certain pins on one switch and go accross the other location I find one or two that show continuity, so I assume that means the control CCU is bad?
  #8 (permalink)
Old 04-06-2012, 09:30 AM
Expert
Default
Hi.
Replace the control board (CCU).
You can return any unused parts even if they been installed.
Post the results.
Simon.
__________________
  #9 (permalink)
Old 05-11-2012, 08:11 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
Simon,
Just replaced the control board and the same failure occurs, it overfills, shuts down and I get 8 flashing green and 1 flashing green, same failure, I would like to return this $150.00 control board as that is not the problem, what do I have to do to retuyrn it and have my credit card issued a credit?
  #10 (permalink)
Old 05-12-2012, 02:56 PM
Expert
Default
Hi.
Check again the air pressure hose from water level switch to the tub for small holes or cracks.
For the return policy contact our customer service 7 day a week.
Thank you.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Overfilling rJtodd Refrigerator & Freezer Repair 0 06-10-2011 09:49 AM
overfilling brinew Washer Repair 0 11-26-2010 06:31 PM
washer overfilling scotte Washer Repair 2 10-08-2009 06:31 AM
Not spinning + Overfilling Coronet Washer Repair 7 07-27-2009 06:54 AM
Overfilling problem gosportbound Washer Repair 2 03-06-2009 03:31 AM
