Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu
Model Number: MAV6000AWW Brand: Maytag Age: More than 10 years
Maytag washer Model Number MAV6000AWW
Problem: Filling and agitation are fine. After rinsing, most water is drained out, but clothes are very wet after spin cycle. After replacing new pump and new belt, the problem was the same.
Richappy told me (2009-07-21) that, “You might have something stuck in the tub. I would pull the spin basket and check. Before doing that, you can shine a light in the spin basket and check for items stuck in the tub.” So I followed the Service Manual, raised the top assembly and leaned it back; Removed the top; Removed the agitator; and removed the four mounting screws. But I could not lift the inner tub up over the center post and out of the cabinet. Two people tried to lift the inner tub, but even the entire machine was up, the inner tub was still connected to the machine. I tried to use a hammer to knock the center shaft while someone lifted the machine, but still could not separate it. I guessed that after so many years usage, the center plastic was melt to block the center shaft to come out. However I checked the space between spin basket and outer tub and did not find anything. Someone suggested that I lower the drain hose to ground level during spin cycle; it turned no help at all. The clothes (only one towel) were still very wet. Anything else can I do? Pleas advise me. Thank you very much. Adam
Ads By Google
Related ModelsMaytag MAV6000AWW Washer, Atlantis Maytag MAV6057AWQ Washer, Atlantis Maytag MAV6057AWW Washer, Atlantis Maytag MAV6200AWQ Washer, Atlantis Maytag MAV6200AWW Washer, Atlantis Maytag MAV6250AWQ Washer, Atlantis Maytag MAV6250AWW Washer, Atlantis Maytag MAV6257AWQ Washer, Atlantis Maytag MAV6257AWW Washer, Atlantis Maytag MAV6260AWW Washer, Atlantis International MAV6300AGW Washer - Top Loading Maytag MAV6300AWQ Washer, Atlantis Maytag MAV6300AWW Washer, Atlantis International MAV6300BGW Washer - Top Loading International MAV6300CGW Washer - Top Loading Maytag MAV6357AWW Washer, Atlantis Maytag MAV6358AWW Washer, Atlantis Maytag MAV6451AGW Washer, Atlantis Maytag MAV6451AWQ Washer, Atlantis Maytag MAV6451AWW Washer, Atlantis Maytag MAV6457AWW Washer, Atlantis Maytag MAV6458AWW Washer, Atlantis Maytag MAV6548AWQ Washer, Atlantis Maytag MAV6548AWW Washer, Atlantis Maytag MAV6601AWQ Washer, Atlantis Maytag MAV6601AWW Washer, Atlantis Maytag MAV6650AWW Washer, Atlantis Maytag MAV7000AWQ Washer, Atlantis Maytag MAV7000AWW Washer, Atlantis Maytag MAV7057AWQ Washer, Atlantis Maytag MAV7057AWW Washer, Atlantis Maytag MAV7200AWQ Washer, Atlantis Maytag MAV7200AWW Washer, Atlantis Maytag MAV7257AWQ Washer, Atlantis Maytag MAV7257AWW Washer, Atlantis Maytag MAV7258AWQ Washer, Atlantis Maytag MAV7258AWW Washer, Atlantis Maytag MAV7260AWW Washer, Atlantis Maytag MAV7260BWW Washer, Atlantis Maytag MAV7357AWQ Washer, Atlantis Maytag MAV7357AWW Washer, Atlantis Maytag MAV7358AWQ Washer, Atlantis Maytag MAV7358AWW Washer, Atlantis Maytag MAV7450AWQ Washer, Atlantis Maytag MAV7450AWW Washer, Atlantis Maytag MAV7501EWW Washer, Atlantis Maytag MAV7504EWW Washer, Atlantis Maytag MAV7550AWQ Washer, Atlantis Maytag MAV7550AWW Washer, Atlantis Maytag MAV7551AWQ Washer, Atlantis Maytag MAV7551AWW Washer, Atlantis Maytag MAV7557EWQ Washer, Atlantis Maytag MAV7557EWW Washer, Atlantis Maytag MAV7580EWQ Washer, Atlantis Maytag MAV7580EWW Washer, Atlantis International MAV7600ACQ Washer - Top Loading International MAV7600AGW Washer - Top Loading Maytag MAV7600AWQ Washer, Atlantis Maytag MAV7600AWW Washer, Atlantis International MAV7600BGW Washer - Top Loading International MAV7600CGW Washer - Top Loading Maytag MAV7650AWQ Washer, Atlantis Maytag MAV7650AWW Washer, Atlantis Maytag MAV7657EWQ Washer, Atlantis Maytag MAV7657EWW Washer, Atlantis Maytag MAV7700AWQ Washer, Atlantis Maytag MAV7700AWW Washer, Atlantis International MAV7750AGW Washer - Top Loading International MAV7750BGW Washer - Top Loading International MAV7750CGW Washer - Top Loading Maytag MAV7757AWQ Washer, Atlantis Maytag MAV7757AWW Washer, Atlantis Maytag MAV8000AWQ Washer, Atlantis Maytag MAV8000AWW Washer, Atlantis Maytag MAV8057AWQ Washer, Atlantis Maytag MAV8057AWW Washer, Atlantis Maytag MAV8260AWQ Washer, Atlantis Maytag MAV8260AWW Washer, Atlantis Maytag MAV8500AWA Washer, Atlantis Maytag MAV8500AWQ Washer, Atlantis Maytag MAV8500AWW Washer, Atlantis Maytag MAV8551AWQ Washer, Atlantis Maytag MAV8551AWW Washer, Atlantis Maytag MAV8557AWQ Washer, Atlantis Maytag MAV8557AWW Washer, Atlantis Maytag MAV8600AWQ Washer, Atlantis Maytag MAV8600AWW Washer, Atlantis Maytag MAV8601AWQ Washer, Atlantis Maytag MAV8601AWW Washer, Atlantis Maytag MAV8757AWQ Washer, Atlantis Maytag MAV8757AWW Washer, Atlantis Maytag MAV9501EWQ Washer, Atlantis Maytag MAV9501EWW Washer, Atlantis Maytag MAV9504EWQ Washer, Atlantis Maytag MAV9504EWW Washer, Atlantis Maytag MAV9557EWQ Washer, Atlantis Maytag MAV9557EWW Washer, Atlantis Maytag MAV9600EWQ Washer, Atlantis Maytag MAV9600EWW Washer, Atlantis Maytag MAV9657EWQ Washer, Atlantis Maytag MAV9657EWW Washer, Atlantis Maytag MAV9750AGW Washer, Atlantis Maytag MAV9750AWQ Washer, Atlantis Maytag MAV9750AWW Washer, Atlantis Maytag MAVT236AWW Washer - Top Loading Maytag MAVT346AWW Washer - Top Loading Maytag MAVT446AWW Washer - Top Loading Maytag MAVT546EWW Washer - Top Loading Maytag MAVT634AWW Washer, Atlantis Maytag MAVT734EWW Washer, Atlantis Maytag MAVT754EWW Washer, Atlantis Maytag MAVT834AWQ Washer, Atlantis Maytag MAVT834AWW Washer, Atlantis Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot International MB1927PEHB Ref - Maytag Int'l Bot Mount International MB1927PEHW Ref - Maytag Int'l Bot Mount International MB2216PUAW Ref - Bottom Mounts International MB2227PEHB Ref - Maytag Int'l Bot Mount International MB2227PEHW Ref - Maytag Int'l Bot Mount Thermador MB245
