Discuss
GE Washer won't turn on
 in
Washer Repair
The topload GE washer will not turn on. Have power to the wiring harness on the control board. No burnt
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer won't turn on
  #1 (permalink)
Old 01-19-2008, 12:07 PM
SnowDogDaddy SnowDogDaddy is offline
Junior Member
SnowDogDaddy is on a distinguished road
Default GE Washer won't turn on
Model Number: WPSE4200A0WW   Brand: GE   Age: 5 - 10 years
The topload GE washer will not turn on. Have power to the wiring harness on the control board. No burnt electrical smell. Can I jumper the lid lock wires to see if that is the issue? How expensive are the control boards?
Thanks a lot,
Chris
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-19-2008, 04:56 PM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Yes, jumper the lid switch and re-check, post results.
__________________
  #3 (permalink)
Old 01-19-2008, 07:29 PM
Junior Member
Default
Scraped off some insulation on two leads to lid switch, did not work when hitting start switch. Took apart control unit, noticed a second switch on top of the start (not visible from assembled control panel). Hit it a couple of times then start worked. Water started filling tub, then stopped way short. Had to hit start several times to get it going again. Suspect control module, have quote for $110-$120, wondering if it is worth it. Been seeing a lot of bad things about GE washers lately.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
agitator won't turn sheryl Washer Repair 1 12-02-2007 04:24 PM
Washer Agitator won't turn nflordeliza Washer Repair 2 10-17-2007 06:04 PM
Broiler won't turn off!! knobjock Oven Repair (including Ranges and Cooktops) 0 08-14-2007 07:22 PM
Dryer won't turn on ag1680 Dryer Repair 2 07-29-2007 09:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
