My roper washer model RAX4232kQ0 won't spin and it's making a noise at the same time. I tried to manual spin the basket but I cant all the other functions with the washer works good but it just will not spin. Please help me figure out whats the problem.
Groups: APP Team
Hi. If the washer agitates and drains check several things: - Take the agitator out and see if the drive block and spin tube connection is good. - Next check the motor coupling, located between the motor and the transmission. - If all this things checks out OK, then most likely the problem is bad clutch. The clutch Part number: AP3094537
Thanks for your help after recieving all the parts and installing them myself with your video guidness I completed the job and my washer machine is working fine now. Thanks you guys are good and your website appliancepartspros.com are cheaper than other retailers.:)
Groups: APP Team
Hi.
I'm glad you were able to fix the problem.
Thank you.
Simon.
