Discuss
kenmore washer 417.42042100 wont spin or agitate
 in
Washer Repair
My kenmore washer 417.42042100 front load has abruptly stopped agitating or spinning. I have checked the door locks and checked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer 417.42042100 wont spin or agitate
  #1 (permalink)
Old 04-02-2012, 08:32 AM
Junior Member
assartorp is on a distinguished road
Default kenmore washer 417.42042100 wont spin or agitate
Brand: Kenmore   Age: More than 10 years
My kenmore washer 417.42042100 front load has abruptly stopped agitating or spinning. I have checked the door locks and checked that the pump is draining. The timer appears to be working and the washer fills and drains but will not turn. The motor does not appear to be engaging when the timer reaches the agitate or spin cylcles. Do I need a new speed controller?
Ads By Google
  #2 (permalink)
Old 04-02-2012, 03:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by assartorp View Post
...I have checked the door locks...
How did you do it?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-02-2012, 05:30 PM
Junior Member
Default
I closed the door and clicked through the cycles on the dial. The washer filled and drained but didn't agitate or spin. When the timer came to the end it was once again possible to open the door. I also opened and closed the detergent drawer while in operation which would start and stop operation. Is there another/better way to check the door lock?
  #4 (permalink)
Old 04-02-2012, 06:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes. You have to measure the resistance across the wax motor (the orange piece on the right side at the following picture) terminals. The normal reading suppose to be about 1500 Ohms. If the reading is incorrect, replace it.
- The door lock assembly Part number: AP4455026
__________________
  #5 (permalink)
Old 04-03-2012, 11:52 AM
Junior Member
Default
alright, I will have a try tomorrow. Any tips on dismantaling the swithch?
  #6 (permalink)
Old 04-03-2012, 12:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The instructions are attached.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore front load washer wont agitate or spin ebcravens Washer Repair 3 01-12-2012 05:50 PM
Kenmore 70 series washer wont agitate, spin, or drain xiuzhiwu Washer Repair 1 07-18-2010 12:59 PM
washer kenmore 80 series top loader fills with water wont drain agitate or spin out dwills Washer Repair 0 05-27-2010 09:24 PM
Kenmore 70 series Wont spin or agitate WendyShooper Washer Repair 2 05-26-2010 11:30 PM
kenmore wont agitate or spin 1946gmc Washer Repair 1 07-26-2009 06:28 AM
