Discuss
will not spin and drain until lid is opened and shut
 in
Washer Repair
The spin and drain cycle wont happen until we open and close lid at certain times of the cycle. we
Appliance Repair Forum > Appliance Repair Help > Washer Repair » will not spin and drain until lid is opened and shut
  #1 (permalink)
Old 08-26-2009, 08:15 AM
Junior Member
jimmyb1966 is on a distinguished road
Default will not spin and drain until lid is opened and shut
Model Number: SAV4655EWW   Brand: Maytag   Age: 1 - 5 years
The spin and drain cycle wont happen until we open and close lid at certain times of the cycle. we have sharpy marks on the timer so we know when to do it. we need to do it twice during each wash
Related Models
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
Amana SBD20S4W REF - SXS/I&W
Amana SBD20TPE REF - SXS/I&W
  #2 (permalink)
Old 08-26-2009, 03:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like there is a problem with the lid switch. It can be worn out or improperly engaged.
- The lid switch assembly Part number: AP4048075
Here are the breakdown diagrams and Replacement parts for MAYTAG SAV4655EWW | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-31-2009, 11:28 AM
Junior Member
Ken Fitzgibbon is on a distinguished road
Default
Jimmy we are having the same problem with a Maytag washer. I don't think the switch is a problem in our case becase the spin will run but only the pump fails to get the water out. Did you find a solution?
ken
  #4 (permalink)
Old 03-16-2012, 12:12 PM
Junior Member
JonToro is on a distinguished road
im having the same problem with a Kenmore model# 110.81090002. Ive tested the lid switch and thats not the problem. The pull-on push-off timer (part # 3347890B) for the washer is defective. My problem now is that i cant find my model # on any parts replacement website cause its an older model. i was able to find the assembly diagrams with the parts #s for a Kenmore model #11098575120 which looks to be constructed exactly the same as my model. Does anyone know if these two models (model# 110.81090002 & model #11098575120) are the same? Is model #11098575120 a later version of model# 110.81090002 maybe?
any help would be much appreciated.
thank you.
  #5 (permalink)
Old 03-16-2012, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jon,
The model number you posted does not come up anywhere. Even the Sears customer service could not locate it. Are you sure this is correct part number? Has been this washer sold in US?
BTW, you stated that the problem is a bad timer. You got the part number from the old timer. This number is still good if you will search without letter "B" which is for the manufacturer use only. Since it was made Whirlpool has replaced this part number with 3946432, which is APP Part number: AP2974739
You can order this timer from APP by clicking on the picture or part number above.
__________________
  #6 (permalink)
Old 03-16-2012, 04:46 PM
Junior Member
Default
Hello Gene,
Thank you for your info, its what i was looking for. The washer was bought in Canada. ive attached a pic of the name plate so you can see for yourself that the model# 110.81090002 really is what i have as a reference.
Like i mentioned before, the assembly diagrams i found for model # 11098575120 seem to be the same as My Model# 110.81090002. The timer you suggest is what model # 11098575120 uses as well.
My problem now is to find out if the Timer Knob from model # 11098575120 also fits my model# 110.81090002 cause thats broken as well. The Sears website has two timer knobs available for model # 11098575120 (PART NUMBER: 3358421 or 3358422), one is 10$ more exspensive than the other and im not sure if either will fit my model# 110.81090002.
anyways, thanks for your help.
  #7 (permalink)
Old 03-16-2012, 05:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Now I see why this model number does not come up on the American Sears web site. The best solution for you in such situation is to call Canadian Sears phone number to find exact part numbers for the timer and the knob.
__________________
  #8 (permalink)
Old 03-16-2012, 05:50 PM
Junior Member
Default
i did. the Canadian Sears service department's only suggestion was to check on appliance repair forums like this one for help because they don't have information on any models older than 10 years. very inefficient system if you ask me.
  #9 (permalink)
Old 03-16-2012, 11:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are absolutely right. Sears is not best company when it comes to the customer service.
So, if the part number for the timer is from the original part then it is still available. As far as I know APP does not ship to Canada. You have to have a valid US address. Maybe you can find the part in Canada?
I probably can help you to find the correct knob for this timer if you'll post the color of it. I'm assuming this is a laundry center and not a single washer.
__________________
  #10 (permalink)
Old 03-17-2012, 09:05 AM
Junior Member
Default
If by laundry center you mean a washer/dryer combo, than yes. the knob is black. ive attached a pic of the front and back of the knob showing the end that has broken off.
thank you very much Gene. your help is very much appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works cosmo99 Washer Repair 1 01-27-2010 11:33 AM
Matag will spin but not pump unless door opened and closed Ken Fitzgibbon Washer Repair 1 11-01-2009 06:53 AM
Dryer continues to spin when door is opened!! badtothebone Dryer Repair 4 10-12-2009 11:39 AM
Kenmore Elite-water wont shut off, now wont drain or spin dbigotis Washer Repair 1 05-12-2009 04:27 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
