| » Top loader washer |
Model Number: WNSE4200A0WW Brand: GE Age: 5 - 10 years
Does everything up to the end of the wash cycle, then it stops and hums. Will not complete the rest of the full cycle (will not drain and then spin and rinse and then final spin).
Related Models |
The most likely thing is that something is hung in the water pump or the pump is bad. Remove all the water then remove the black hose on top of the pump to see if anything is in the pump. Note even though you remove all the water be ready for water when you take that black hose off. Clothes Washer Repair Guide
applianceman, Yes your were correct. Check the pump! I got bored and went into our garage and placed the dryer up in the bed of my Ranger p/u trk and took off the front cover and began looking around and disconnected the pump unit and water poured out. I looked inside both top and side tubes and seen gunk!!!! We have well water out here on this farm. I tapped gently and kept wiggling it in a bucket of water and cleaned most gunk out, rehooked and gave it a temp try out filling with buckets of water (small load setting) in the garage and it worked just fine. I brought it back in again and its working as good as can be. Wow I got lucky. I then sat down to check the email and read your reply, Your awesome!!! That was it exactly and I bumbled onto what you guesstamated to a "T". Thank you applianceman, your good people!!!!
| Display Modes | |
| Stackable Washer Frontend loader | sherry1105 | Washer Repair | 1 | 11-01-2008 06:39 AM |
| whirlpool top loader washer | kpenny | Washer Repair | 0 | 07-16-2008 12:03 PM |
| washer front loader | fred m | Washer Repair | 2 | 05-13-2008 07:12 PM |
| Whirpool washer top loader | rob777 | Washer Repair | 1 | 03-19-2008 12:40 PM |
| front loader washer | Donald Belanger | Washer Repair | 4 | 12-07-2007 05:53 PM |
