I have water dripping from bottom of tub. What do I need to do to fix this?
Originally Posted by: David Rayle I have water dripping from bottom of tub. What do I need to do to fix this? If it's coming from around where the transmission goes through the outer tub it appears you'll need a new hub and seal kit. A bit of a job. See below. Part number: AP2405464
