Discuss
Roper won't spin
 in
Washer Repair
The original problem started with the tub not spinning durning the spin cycle. I would open the lid and hold
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper won't spin
  #1 (permalink)
Old 01-19-2008, 12:05 AM
oznib oznib is offline
Junior Member
oznib is on a distinguished road
Post Roper won't spin
Model Number: RAL5144BLO   Brand: Roper   Age: More than 10 years
The original problem started with the tub not spinning durning the spin cycle. I would open the lid and hold the lid switch down with a screw driver and spin the tub by hand. The speed would slowly increase and eventually gain the proper RPM's. Now, this temporary method does not work. I don't hear the motor, the tub does not spin, and the pump does not work leaving the washer full of water. Any repair suggestions would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-19-2008, 02:43 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you hear a hum in spin, you have something clogged in the pump, just clean out. If no hum probably a bad lid switch. If slow spin, you have a bad clutch and sticking brake shoes.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper washer will not spin, agitate, pump litexp2 Washer Repair 16 09-26-2008 01:53 PM
Roper washing machine shakes during spin cycle... zoe1594 Washer Repair 3 06-09-2008 01:22 PM
roper maximum destruction Washer Repair 2 01-07-2008 04:37 PM
Roper Won't power up cmedics Dishwasher Repair 1 11-14-2007 10:18 PM
Roper washer will not spin rodtamara Washer Repair 0 11-12-2007 04:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
