Discuss
water leaking between transmission and tub
 in
Washer Repair
My washer is leaking between the tub and transmission. I don't see and cracks in tub. It must be the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water leaking between transmission and tub
  #1 (permalink)
Old 08-25-2009, 06:11 PM
Junior Member
jsteward is on a distinguished road
Default water leaking between transmission and tub
Model Number: fwsb34rgs0   Brand: Frigidaire   Age: 1 - 5 years
My washer is leaking between the tub and transmission. I don't see and cracks in tub. It must be the seal.So how can I fix this leak myself ?
Related Models
Frigidaire FWSB34RGS0 Frg(v0) / Washer
Frigidaire FWSB34RGS1 Washer - Fwsb34rgs1 - Frigidaire
Frigidaire FWSB55RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWSB55RGS1 Washer - Frigidaire
Frigidaire FWSB5700DS0 Frigidaire/washer
Frigidaire FWSB6600ES0 Frigidaire/washer
Frigidaire FWSB6600ES1 Frigidaire/washer
Frigidaire FWSB6600FS0 Frigidaire/washer
Frigidaire FWSB6600FS1 WASHER
Frigidaire FWSB67RGS0 Washer - Frigidaire - Best Buy
Frigidaire FWSB67RGS2 Washer - Frig/best Buy
Frigidaire FWSB7800DS0 Frigidaire/washer
Frigidaire FWSC235RFS3 Washer - Fwsc235rfs3
Frigidaire FWSC34RGS1 Washer - Fwsc34rgs1
Frigidaire FWT425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWT445GC WASHER
Frigidaire FWT445GCS0 Frg(v0) / Washer
Frigidaire FWT445GE WASHER
Frigidaire FWT445GES0 Frg(v0) / Washer
Frigidaire FWT445GES1 Frg(v0) / Washer
Frigidaire FWT445GES2 Frg(v0) / Washer
Frigidaire FWT449GFS0 Frg(v0) / Washer
Frigidaire FWT449GFS1 Frg(v0) / Front Load Washer
Frigidaire FWT449GFS2 Frg(v0) / Free Standing Washer
Frigidaire FWT645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWT645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS0 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWT648GHS0 Frg/washer
Frigidaire FWT867GHQ0 Frg/washer
Frigidaire FWT867GHS0 Frg/washer
Frigidaire FWTB59RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB69RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB8200DS0 Frigidaire/washer
Frigidaire FWTBB30DS0 Frigidaire/washer
Frigidaire FWTR425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWTR445RFS0 Frg(v0) / Washer
Frigidaire FWTR445RFS1 Frg/washer
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
  #2 (permalink)
Old 08-27-2009, 01:16 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This service manual should take you through the process. It is not difficult, but you do need to work slowly and carefully, and just take your time.
http://frigidaireservicetips.com/pdfs/489_5.pdf
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
coils feezing up and water filter leaking out water beth hatcliff Refrigerator & Freezer Repair 1 02-14-2010 04:28 AM
Water leaking from water valve coloradocj5 Refrigerator & Freezer Repair 0 08-15-2009 12:46 PM
Washer transmission leaking and squealing pfries Washer Repair 1 06-17-2009 04:50 PM
Transmission Leaking Steve L Washer Repair 3 06-17-2009 10:01 AM
Stackable Frigidaire washer is leaking from underneath centerpost/transmission gregrao Washer Repair 1 09-26-2008 02:08 PM
