Discuss
Admrial washer does not advance cycle
 in
Washer Repair
Hello, My admiral washer machine stopped at mid cycle and does not spin, drain or continue. MAIN knob will not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Admrial washer does not advance cycle
  #1 (permalink)
Old 03-31-2012, 08:18 AM
Junior Member
hime is on a distinguished road
Unhappy Admrial washer does not advance cycle
Model Number: LNC6764A71   Brand: Admiral   Age: 5 - 10 years
Hello,
My admiral washer machine stopped at mid cycle and does not spin, drain or continue. MAIN knob will not ADVANCE.
I emptied, and I checked the following:
1) Lid switch and works fine. It clicks,I took it out and check continuity and it is good.
2)The drain pump is good. I took it off and it is clean an rotates fine
3) Belt is fine.
4) All pulleys rotate freely manually from underneath, after taking belt off.
5) ordered a new timer and belt and installed them. Same problem: Main Knob will not advance. I can hear a low sound that you always hear when it would be getting ready to advance to next step on cycle but it never advances.
6) Water supply is fine and fills up ok.
7) When I spin main pulley manually from underneath without a belt, the agitator moves fine.
Machine will not spin or rinse or drain even if i try to move main knob manually to do these. If I set know right before "oFF" it will advance to off and buzzer will go on.
I need advise what to do next.
Thank you very much
Related Models
Admiral LNC6764A71 WASHER-TOP LOADING
Admiral LNC6766A00 WASHER-TOP LOADING
Admiral LNC6766A01 WASHER-TOP LOADING
Admiral LNC6766A71 WASHER-TOP LOADING
Admiral LNC6766A77 WASHER-TOP LOADING
Admiral LNC6766B71 WASHER-TOP LOADING
Admiral LNC7760A71 DRYER- ELE
Admiral LNC7764A71 DRYER- ELE
Admiral LNC7764A77 DRYER- ELE
Admiral LNC7766A00 DRYER- ELE
Admiral LNC7766A71 DRYER- ELE
Admiral LNC7766B71 DRYER- ELE
Admiral LNC8760A01 DRYER- GAS
Admiral LNC8760A71 DRYER- GAS
Admiral LNC8760A77 DRYER- GAS
Admiral LNC8764A71 DRYER- GAS
Admiral LNC8766A00 DRYER- GAS
Admiral LNC8766A71 DRYER- GAS
Admiral LNC8766B71 DRYER- GAS
 LP-C303R20 Air Conditioner
 LP070CED Air Conditioner
 LP070CED-Y8 Air Conditioner
 LP070CED1 Air Conditioner
 LP070HED Air Conditioner
 LP070HED-Y8 Air Conditioner
 LP070HED1 Air Conditioner
 LP090CED Air Conditioner
 LP090CED-Y8 Air Conditioner
 LP090CED1 Air Conditioner
 LP090HED Air Conditioner
 LP090HED-Y8 Air Conditioner
 LP090HED1 Air Conditioner
 LP090HEM Air Conditioner
 LP091CEM-Y8 Air Conditioner
 LP091HEM Air Conditioner
 LP1200DXR Air Conditioner
 LP120CED Air Conditioner
 LP120CED1 Air Conditioner
 LP120CEM Air Conditioner
 LP120CM3 Air Conditioner
 LP120HED Air Conditioner
 LP120HED-Y8 Air Conditioner
 LP120HED1 Air Conditioner
 LP120HEM Air Conditioner
 LP121CEM-Y8 Air Conditioner
 LP121HEM Air Conditioner
 LP121HEM-Y8 Air Conditioner
Amana LP13300.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13300.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP13600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP13610.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13610.B MWAVE - FAMILY SIZE (60 HZ)
 LP150CED Air Conditioner
 LP150CED-Y8 Air Conditioner
 LP150CED1 Air Conditioner
 LP150HED Air Conditioner
 LP150HED-Y8 Air Conditioner
 LP150HED1 Air Conditioner
 LP155HED1 Air Conditioner
Amana LP16400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP16600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP16610.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16610.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP24400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP24400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP24600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP24600.B MWAVE - FAMILY SIZE (60 HZ)
 LP6000ER Air Conditioner
Amana LP83400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83430.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83430.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83620.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83630.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83630.B MWAVE - FAMILY SIZE (60 HZ)
Frigidaire LPGF3091KSA GAS RANGE
Frigidaire LPGF3091KSB GAS RANGE
Frigidaire LPGF3091KSD GAS RANGE
Frigidaire LPGF3091KSE GAS RANGE
Frigidaire LPGF3091KSF GAS RANGE
Frigidaire LPGF3091KSG GAS RANGE
Frigidaire LPGF3091KSH GAS RANGE
Frigidaire LPGF3091KSJ GAS RANGE
Frigidaire LPHS2687KF0 REFRIGERATOR
Frigidaire LPHS2687KF1 REFRIGERATOR
Frigidaire LPHS2687KF2 REFRIGERATOR
Frigidaire LPHS2687KF4 REFRIGERATOR
Admiral LPK5404ARW KITCHEN COMPACT
Admiral LPR1115ADW RANGE- F/S STD GAS
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Frigidaire LPUS2686LF0 REFRIGERATOR
Frigidaire LPUS2686LF1 REFRIGERATOR
Frigidaire LRA050XT70 ROOM AIR CONDITIONER
Frigidaire LRA050XT71 ROOM AIR CONDITIONER
Frigidaire LRA050XT710 ROOM AIR CONDITIONER
Frigidaire LRA050XT711 ROOM AIR CONDITIONER
Frigidaire LRA050XT712 ROOM AIR CONDITIONER
Frigidaire LRA050XT713 ROOM AIR CONDITIONER
Frigidaire LRA050XT714 ROOM AIR CONDITIONER
Frigidaire LRA050XT715 ROOM AIR CONDITIONER
Frigidaire LRA050XT716 ROOM AIR CONDITIONER
Frigidaire LRA050XT717 ROOM AIR CONDITIONER
Frigidaire LRA050XT718 ROOM AIR CONDITIONER
Frigidaire LRA050XT719 ROOM AIR CONDITIONER
Frigidaire LRA050XT72 ROOM AIR CONDITIONER
Frigidaire LRA050XT720 ROOM AIR CONDITIONER
Frigidaire LRA050XT721 ROOM AIR CONDITIONER
Frigidaire LRA050XT722 ROOM AIR CONDITIONER
Frigidaire LRA050XT723 ROOM AIR CONDITIONER
Frigidaire LRA050XT724 ROOM AIR CONDITIONER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not advance after wash cycle to rinse cycle jtz Washer Repair 1 10-04-2010 04:29 PM
Washer cycle won't advance four_dee2000 Washer Repair 1 01-04-2010 07:16 AM
Admrial Washer wont spin and smoke Shawn4455 Washer Repair 1 05-08-2009 05:48 PM
Washer cycle does not advance ermike02 Washer Repair 0 03-13-2008 05:25 PM
washer cycle won't advance tlaw63 Washer Repair 1 03-11-2008 03:11 PM
