Washer on permanent press cycle will not spin dry. It does drain ok. Turned it to gentle spin and still nothing, but on normal cycle it will spin. Next time on permanent press it wouldn't spin again and not on normal but would on gentle. Then on permanent press it wouldn't spin again but back to normal cycle and it would. Is it possible it is my dial?
Groups: APP Team
Hi. From what you are describing most likely the problem is with the timer. The timer Part number: AP3020256
If you will have any problem with installation, get back to us. You can always return unused parts even if they been installed. Thank you. Post the results. Simon.
