| » Shaking violently during spin cycle |
Model Number: WFW8300SW05 Brand: Whirlpool Age: 1 - 5 years
Hello:
Just bought whirlpool duet sport used. Ran the clean washer cycle, worked fine. First load of clothes on whitest whites setting, the washer shook violently once the high speed spin cycle was initiated and the stacked dryer fell off the top, we had left the house and came home to this mess. It seems to work well in all other phases of the wash cycle. We've tried to level it as best we can using a good carpenters level, one of the leveling feet is beat up, it still shook in a major way, lifting itself off the floor an inch or two after leveling again. I have opened up the top and front lower compartments to look for any obvious problems. Springs look good but do they wear out? There are 3 shock absorbers, but I can't tell how to test them for wear. Should there be 4 shocks? Help, I don't know what to do next to fix it. PGAfuture Ads By Google Related Models |
It is a good possibility that a support item is broken and sometimes it is hard to see any damage. Change them out and check out the rest of the support area while you are in there.
__________________
Quote:
When you say change out, what parts are you referring to aside from the shock absorbers? I was considering changing out the two springs on the upper porting of the outer tub. I noticed that the large wheel that the belt rides on is very slightly out of round, the belt seems to ride around it well. There are 4 bolts on the back of the machine that seem to hold the tub in place, I'm guessing that you may be referring to these as the support system? |
I would change out the springs and the big pulley to start with. Unfortunatley a lot of times there can be a problem that is just not visible.
Given the problems with these models you may want to think about replacing it if you cannot get it fixed with these low cost parts.
__________________
| Display Modes | |
| bad shaking on spin cycle | rawhiles | Washer Repair | 3 | 02-13-2012 06:05 AM |
| tub moves up and down violently in spin cycle | mookle_1967 | Washer Repair | 0 | 11-24-2010 10:05 AM |
| Kenmore Washer Shakes violently during spin cycle | thielen25 | Washer Repair | 1 | 05-14-2010 05:02 PM |
| Front load tub bounces violently in spin cycle | karassdh | Washer Repair | 1 | 01-02-2009 05:48 AM |
| Roper washing machine shaking violently | texasgal | Washer Repair | 8 | 06-03-2008 08:49 AM |
