Rank:: Member
Have had this washer quite a while. I just did a load of clothes & it will not spin. Everything else works, fills with water, washes & drains but will not spin...
All help appreciated, jackg.
Since it will drain this suggests the motor is running but the basket is not turning.
Try changing out the clutch, and take a look at the Sticky on direct drive brakes from Richappy at the top of the main washer page for additional info.
There is also a video in the video library.
