| » Boot Seal Blues |
Model Number: WBVH5100HWW Brand: GE Age: 1 - 5 years
Somebody...Anybody,
I have a GE frontload washer that has been leaking. I have found the cause. Evidently, an inkpen found its way into the wash and pierced a hole in the door boot seal. I was going to pay someone to fix it until I found out how much it was going to cost. I know that I am capable of doing the repair myself...Well, at least following some instruction from a professional who is just itching to help me with my problem. Two things, where is the best place to buy GE parts online and can anyone give me some steps to replacing the boot seal for this particular model (WBVH5100HWW)? Thanks - RJH Related Models |
If it is at all possible try to patch the hole rather than replace the boot. It is very difficult to get the boot back on after you have taken it off.
I have used "goop" sealant to repair these, and others have reported success with bycycle tube patches.
__________________
sidfink43 -
I patched the hole in the boot seal on my GE washer as you suggested and it worked great. It has been 2 weeks now and at least 15 loads of laundry and no leaks. I used a bicycle tube repair kit and the goop. I put one patch disc above and one below the hole and then applied a healthy coat of goop. Maybe a bit of overkill but better safe than sorry! Thanks again for your help. |
| Display Modes | |
| Ice Maker Blues | man.tuck | Refrigerator & Freezer Repair | 0 | 08-16-2009 03:21 PM |
| mounting stem & boot seal + tub bearing replacement | abruzzinom@bellsouth.net | Washer Repair | 2 | 01-19-2009 06:02 AM |
| Tub to door boot (seal) | FDAR | Washer Repair | 2 | 12-03-2008 09:26 PM |
| door seal +boot +gasket install | misterfixall | Washer Repair | 0 | 10-30-2008 01:29 PM |
| Mounting stem and boot seal replacement | Fishinfool | Washer Repair | 1 | 08-26-2008 11:17 PM |
