Discuss
whirpool doesn't spin all the time
 in
Washer Repair
washer doesn't spin all the time. It seems if it isn't spinning, if I grab the basket and try to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirpool doesn't spin all the time
  #1 (permalink)
Old 03-28-2012, 06:47 PM
Junior Member
jbalbo is on a distinguished road
Default whirpool doesn't spin all the time
Model Number: lsq9549lw0   Brand: Whirlpool   Age: 5 - 10 years
It seems if it isn't spinning, if I grab the basket and try to spin it() has alot of friction ) it starts to start spinning, not sure if its spinning as fast as it should, it does shake preety good after afew seconds.
Thanks In advance
Joe
Ads By Google
Related Models
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Whirlpool LSQ9549PW2 Automatic Washer
Whirlpool LSQ9549PW3 Automatic Washer
Whirlpool LSQ9549PW5 Automatic Washer
Whirlpool LSQ9549PW6 Automatic Washer
Whirlpool LSQ9550PW0 Automatic Washer
Whirlpool LSQ9550PW1 Automatic Washer
Whirlpool LSQ9550PW2 Automatic Washer
Whirlpool LSQ9550PW3 Automatic Washer
Whirlpool LSQ9550PW4 Automatic Washer
Whirlpool LSQ9560PW0 Automatic Washer
Whirlpool LSQ9560PW1 Automatic Washer
Whirlpool LSQ9560PW3 Automatic Washer
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
Whirlpool LSQ9650PW0 Automatic Washer
Whirlpool LSQ9650PW1 Automatic Washer
Whirlpool LSQ9650PW2 Automatic Washer
Whirlpool LSQ9650PW3 Automatic Washer
Whirlpool LSQ9650PW4 Automatic Washer
Whirlpool LSQ9659LG0
Whirlpool LSQ9659LG1 Automatic Washer
Whirlpool LSQ9659LW0
Whirlpool LSQ9659LW1 Automatic Washer
Whirlpool LSQ9659PG0 Automatic Washer
Whirlpool LSQ9659PG1 Automatic Washer
Whirlpool LSQ9659PG2 Automatic Washer
Whirlpool LSQ9659PG3 Automatic Washer
Whirlpool LSQ9659PG4 Automatic Washer
Whirlpool LSQ9659PW0 Automatic Washer
Whirlpool LSQ9659PW1 Automatic Washer
Whirlpool LSQ9659PW2 Automatic Washer
Whirlpool LSQ9659PW3 Automatic Washer
Whirlpool LSQ9659PW4 Automatic Washer
Whirlpool LSQ9660PG0 Automatic Washer
Whirlpool LSQ9660PG1 Automatic Washer
Whirlpool LSQ9660PG2 Automatic Washer
Whirlpool LSQ9660PG3 Automatic Washer
Whirlpool LSQ9660PG4 Automatic Washer
Whirlpool LSQ9660PW0 Automatic Washer
Whirlpool LSQ9660PW1 Automatic Washer
Whirlpool LSQ9660PW2 Automatic Washer
Whirlpool LSQ9660PW3 Automatic Washer
Whirlpool LSQ9660PW4 Automatic Washer
Whirlpool LSQ9665JQ0
Whirlpool LSQ9665JQ1
Whirlpool LSQ9665JQ2
Whirlpool LSQ9665JQ3
Whirlpool LSQ9665JQ4
Whirlpool LSQ9665JT0
Whirlpool LSQ9665JT1
Whirlpool LSQ9665JT2
Whirlpool LSQ9665JT3
Whirlpool LSQ9665JT4
Whirlpool LSR4100HQ0
Whirlpool LSR4311DQ0
Whirlpool LSR5100HQ0
Whirlpool LSR5100KQ0
Whirlpool LSR5100LQ0
Whirlpool LSR5101LQ0
Whirlpool LSR5101LQ1 Automatic Washer
Whirlpool LSR5102LQ1 Automatic Washer
Whirlpool LSR5121HQ0
Whirlpool LSR5121JQ0
Whirlpool LSR5132AG0
Whirlpool LSR5132AN0
Whirlpool LSR5132AW0
Whirlpool LSR5132HQ0
Whirlpool LSR5132HQ1
Whirlpool LSR5132JQ0
Whirlpool LSR5132JQ2
Whirlpool LSR5132PQ0 Automatic Washer
Whirlpool LSR5132PQ1 Automatic Washer
Whirlpool LSR5132PQ3 Automatic Washer
Whirlpool LSR5132PQ4 Automatic Washer
Whirlpool LSR5232DW0
Whirlpool LSR5232LQ0
  #2 (permalink)
Old 03-28-2012, 09:12 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Sounds like the clutch maybe slipping and needs to be replaced.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 03-29-2012, 03:53 AM
Junior Member
Default
any instruction on replacing clutch?
OK I found instructions on replacing the clutch..
Anything else I should maybe replace while I have the motor and shaft out?
  #4 (permalink)
Old 03-29-2012, 06:56 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your brake shoes are probably dragging. Pull off the pump and turn the motor shaft clockwise. If hard to turn, you have bad brake shoes. You can check my sticky above, "replacing direct drive washer brake shoes".
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool washer do not drain or spin. RAYMOND5JACKSON Washer Repair 1 05-06-2011 07:05 AM
whirpool fridge not retarting after defrost time coconut sunrise Refrigerator & Freezer Repair 4 10-09-2010 02:58 AM
Whirpool Washer Spins And Drains At Same Time Spilling Over Top potatohead Washer Repair 1 01-20-2010 04:13 AM
whirpool don't spin handyman68 Washer Repair 1 05-23-2009 06:08 PM
Spin cycle some time good, some time slow a3d Washer Repair 5 12-04-2008 05:30 PM
