AppliancePartsPros.com
Appliance Repair Help
Washer Repair
won't agitate but will spin smells burnt makes noise
My old A190, won't agitate anymore. It started with an intermitant smell & a screach a month ago. Then This week I had to reduce a load to 2 polos to agitate. Now It will spin. But on wash cycle it just sits ther quitly for a few minutes. then a faint smell and a slight noise.
Examine the belt for any problems, but I suspect your transmission is binding in which case a new machine is the likely solution.
Good luck.
Washer Repair
