santaisa
#1 Posted : Friday, August 21, 2009 12:48:07 PM(UTC)
santaisa
I am having a problem with my washer. I was waching my clothes and then I had to stop the washer because I smelled something burnt and the washer machine never drained and also its making some noise
#2 Posted : Friday, August 21, 2009 3:46:49 PM(UTC)
There is not enough information to say anything specific. You have to pinpoint the source of the smell. Remove the bottom access panel and rear panel and run the washer. Open the control panel and inspect the control board. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WFW8300SW02 | AppliancePartsPros.com
santaisa
#3 Posted : Friday, August 21, 2009 4:55:42 PM(UTC)
santaisa
I have remove the access panel and ran the washer also everything was running fine but after aprox 4 minutes I heard a noise coming from the bottom of the washer i dont know the name of that part but it looks like its the part that drains the water out when I heard the noise the hose that drains the water out vibrated
#4 Posted : Saturday, August 22, 2009 7:52:22 PM(UTC)
Quote:
...it looks like its the part that drains the water out when I heard the noise the hose that drains the water out vibrated...
It is the drain pump (you can see it if you click on the link I posted previously) and noise and vibration are normal. You claimed the burning smell in your first post. Did it smell again?
santaisa
#5 Posted : Sunday, August 23, 2009 6:24:41 PM(UTC)
santaisa
I already fixed the washer I have removed the water pump and cleaned it out. I found a lot trash inside the water pump like coins,shoe lases,trash ect . thanks for your help
