rich4rich
#1 Posted : Friday, August 21, 2009 9:04:35 AM(UTC)
rich4rich
Hello,My problem is my washing machine only goes on in the spin cycle.It spins,and the timer is working in the spin cycle,but when I turn to any of the wash cycles,the timer doesnt move and the water does not come on.I disconnected the hot & cold water hoses to see if they were clogged ,but they were fine.Please help,Richard
sidfink43
#2 Posted : Saturday, August 22, 2009 2:36:17 PM(UTC)
sidfink43
Hi Richard
Take off the front panel, then take off the screws which hold down the top and flip it up.
Put the machine timer in the start position where it should be filling with water and test to see if 120v is going to the water valves. If it is, you will need to replace the water valves.
If no current is going to the valves, the timer is the likely problem.
Good luck, let us know what you find out.
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
Maytag washing machine MHW6630HW - looking for electrical diagram (Washer Repair)
by jessman1128 2/8/2023 12:45:11 PM(UTC)
