Discuss
Washer makes extremely loud noise during spin
 in
Washer Repair
The washer makes an extremely loud squeal when spinning. It also stops very abruptly when opened. The other symptom was
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer makes extremely loud noise during spin
  #1 (permalink)
Old 01-17-2008, 11:57 AM
mcook001 mcook001 is offline
Junior Member
mcook001 is on a distinguished road
Default Washer makes extremely loud noise during spin
Model Number: PAV 3300 AWW   Brand: Maytag   Age: 1 - 5 years
The washer makes an extremely loud squeal when spinning. It also stops very abruptly when opened. The other symptom was it completely quit spinning. I turned the drum a little to see if it would move at all and then turned the unit back on and the original problem came back with the loud noise while it was spinning. Any help or advice would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-17-2008, 05:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad bearing on the drain pump. The pump has to be replaced.
- The part number for the drain pump is AP3447809
Here are the break down diagrams for the Maytag washer Model PAV3300AWW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer makes grinding noise. wont spin montanaJohn Washer Repair 3 01-21-2008 07:52 PM
Washer makes noise and does not spin rjr Washer Repair 1 12-30-2007 03:08 AM
dryer makes loud buzzing noise won't tumble maureen Dryer Repair 3 12-28-2007 11:08 PM
Makes loud clunking noise drdesl2 Washer Repair 4 09-30-2007 02:51 PM
Makes loud noise when spinning waggie Washer Repair 0 09-03-2007 02:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
