Discuss
Maytag Washer Neptune Board
 in
Washer Repair
My Control Board Has 2 Burnt Resistors (r75 & R11) On The Board. I Was Told To Replace The Control
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer Neptune Board
  #1 (permalink)
Old 08-20-2009, 04:12 PM
Junior Member
EVAGELLIA is on a distinguished road
Default Maytag Washer Neptune Board
Model Number: MAH4000AWW   Brand: Maytag   Age: 5 - 10 years
My Control Board Has 2 Burnt Resistors (r75 & R11) On The Board. I Was Told To Replace The Control Board Part #22002989. What Other Part Might Need To Be Replcaed With It??? What Would Cause Two Resistors To Burn Up??? Would A Door Switch Or Lock??? Please Help!!! Is This Worth Fixing???
Ads By Google
Related Models
Maytag MAH4000AWW Washer - Horizontal Axis
Maytag MAH4000BWQ Washer - Horizontal Axis
Maytag MAH4000BWW Washer - Horizontal Axis
Maytag MAH5500AWQ Washer - Horizontal Axis
Maytag MAH5500AWW Washer - Horizontal Axis
Maytag MAH5500BWQ Washer - Horizontal Axis
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
  #2 (permalink)
Old 08-21-2009, 07:30 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Eva
You need to replace the wax motors which control the door switch and which you may also have on the dispensor mechanism. For reasons known only to Maytag, and maybe not even to them, these wax motors cause a failure of the control board.
With respect to your question about is it worth it, I would say if you can do the work yourself, and you otherwise like the washer and you do not suspect there are any other problems, go ahead. If you have to pay to have this done, or you are not particularly happy with the machine I would say take the money you were going to spend on the old Neptune and replace it with a no frills top loading machine. It will get your clothes just as clean, and should give you years of trouble free operations.
Good luck.
__________________
  #3 (permalink)
Old 08-22-2009, 09:50 AM
Member
NeptuneHelp is on a distinguished road
Default Maytag Neptune front loader door latch blues...
Quote:
Hello,
The door latch wax motor (12002535) shorts out and damages the Q6 and R11 on the Neptune Machine Control board. See neptune help song for a video that explains the issue and the low cost solution. You can replace the components on the control board and see if that corrects the door locking / no spin issue for about $35. If you still have issues then the control board will have to be replaced.
I hope this helps. Check out neptune bearing if your Neptune is getting loud in the spin cycle so you can replace your bearings and seal kit before they get too bad. Save $800 by doing it yourself!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag neptune washer PURNRG Washer Repair 7 08-08-2009 09:03 AM
Maytag Neptune Machine control board R11 ohm value sjh348 Washer Repair 5 07-12-2009 11:19 AM
Time Control Board Maytag Neptune terryb Washer Repair 7 04-12-2009 06:40 AM
How to wire up new motor control board maytag neptune anniechoco Washer Repair 0 12-30-2008 05:36 PM
Replace controll board on Maytag Neptune Jim Freddy Washer Repair 0 07-02-2008 11:08 AM
