I was told to buy a new belt to put on , I did that and the washer worked fine for a few loads and then all of a sudden the belt has loosened up and now the wheel between the motor and pump just spins. Is there a way to tighten it up or do I have to remove it again and start over?? Someone PLEASE HELP ME figure this out....
