Gail
The washer will not spin after regular wash or on delicate cycles, it just washes again in the same water in rinse cycle, after the rinse cycle it will then spin out. Is this timer related?
Very likely the problem is a bad timer. If you need the correct part number then post the serial number of the washer.
Gene. |
| All times are GMT -7. The time now is 04:39 PM. |
