Discuss
Noise When Spinning
 in
Washer Repair
I have a Kenmore Washer Model 11092595210 and have ordered parts from you before, but I need help to determine
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noise When Spinning
  #1 (permalink)
Old 03-26-2012, 01:49 PM
Junior Member
mycountryanimals is on a distinguished road
Default Noise When Spinning
Model Number: 11092595210   Brand: Kenmore   Age: More than 10 years
I have a Kenmore Washer Model 11092595210 and have ordered parts from you before, but I need help to determine what my new problem is. The washer started making a noise when spinning like it was out of balance, but that is not the problem. I checked it empty and it makes a loud clunk when it starts spinning and then the noise continues like it is out of balance. Be aware that it still works, fills, washes, spins, just this noise so know something is wrong but don't want to throw parts at it. (Money issue). So, is there anyone there who could point me in the right direction as what to check on the washer, so I could then order my parts? Thanks
Ads By Google
Related Models
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
Kenmore 11098518200 ELECTRIC DRYER
Kenmore 11098518210 ELECTRIC DRYER
Kenmore 11098518220 ELECTRIC DRYER
Kenmore 11098518230 COMPACT ELECTRIC DRYER
Kenmore 11098518400 ELECTRIC DRYER
Kenmore 11098518410 ELECTRIC DRYER
Kenmore 11098518420 ELECTRIC DRYER
Kenmore 11098518430 COMPACT ELECTRIC DRYER
Kenmore 110985200 SEARS HEATER/FAN/LIGHT
Kenmore 110985300 FAN/LIGHT
Kenmore 110985400 BULB HEATER/FANS
Kenmore 110985500 BULB HEATER/FANS
Kenmore 110985501 BULB HEATER/FAN
Kenmore 110985600 SEARS BATHROOM FANS
Kenmore 110985700 SEARS BATHROOM FANS
Kenmore 11098572200 ELECTRIC DRYER
Kenmore 11098572210 ELECTRIC DRYER
Kenmore 11098572400 ELECTRIC DRYER
  #2 (permalink)
Old 03-26-2012, 05:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the washer cabinet, the pump and the motor. Check how freely the transmission is moving in both directions by rotating the coupler. When it moved CW, the clutch housing should spin, CCW it should agitate. Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-26-2012, 09:22 PM
Junior Member
When my husband returned home, I had him listen to it spin. I plugged in the washer and put it on spin and pushed the lid switch to start the washer and it made a loud noise when it started to spin, spinned fine and also stopped spinning fine, but made a clunking noise while spinning. My husband said it sounded like a bearing or gear.
When turning the coupler CW, it eventually hung up. So, I am thinking it is in the gear case. Possibly the Spin Pinion and Gear or would it possibly be the Driver Brake Cam? Is the Driver Brake Cam supposed to be able to turn back and forth about a quarter of a turn? Thanks for your input.
  #4 (permalink)
Old 03-27-2012, 02:18 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You might have a loose drive block nut, the item that tightens the spin basket to the spin tube. Pull the agitator and check. You will need the special spanner wrench to tighten it.
__________________
  #5 (permalink)
Old 03-27-2012, 02:21 AM
Senior Expert
APP Volunteer
Default
You can also remove the pump and turn the motor shaft clockwise with an adjustable wrench, then feal for transmission turning problems when the clutch housing turns.
__________________
  #6 (permalink)
Old 03-27-2012, 10:58 AM
Junior Member
My husband removed the gearcase cover and the spin gear has a 3/4 inch spot that the teeth are about 1/2 the height of the other teeth. His opinion is that is what was making the thump, thump, thump noise as it was spinning. Would that be your opinion also? Any other ideas or advice? Thanks.
  #7 (permalink)
Old 03-27-2012, 03:34 PM
Senior Expert
APP Volunteer
Default
I have never fixed one of these.To repair it, you would need to flush the tranny with some oil based solvent like kerosene to clean the nylon gear pieces out, then install a gear set AP3094405, seems easy to do.
Your gear failure was probably from a overload, or something stuck in the tub. If the brake shoes are dragging, that could be cause of the failure.
__________________
  #8 (permalink)
Old 03-27-2012, 05:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The whole new gear case would cost you more money, but it will make the repair much more reliable and it comes with one year warranty.
- The gear case (transmission) Part number: AP3096209
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
quit spinning noise cardoc777 Washer Repair 3 02-22-2012 03:53 PM
screeching noise when spinning norjen13 Washer Repair 0 06-05-2011 07:09 PM
squeeking noise when spinning, like a high pitched drill noise norjen13 Washer Repair 0 06-05-2011 04:30 PM
Loud Noise when Spinning Rudy Garza Washer Repair 1 10-08-2009 05:54 AM
Makes loud noise when spinning waggie Washer Repair 0 09-03-2007 01:05 PM
