Discuss
kenmore washer no cold water
 in
Washer Repair
my washer (80series) only accepts cold water when i turn the hose connection on and off. every cycle cold comes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer no cold water
  #1 (permalink)
Old 08-19-2009, 07:28 AM
Junior Member
jasonkeg is on a distinguished road
Default kenmore washer no cold water
Model Number: 110.92281100   Brand: Kenmore   Age: 5 - 10 years
my washer (80series) only accepts cold water when i turn the hose connection on and off. every cycle cold comes on i have to flip the switch...the hot water has no issues. what part do i need to replace, i was told a pump of some sort but i can't locate a part... thank you
Ads By Google
Related Models
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
  #2 (permalink)
Old 08-19-2009, 08:29 AM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Quote:
Not sure I completely understand, but I think you're saying the cold water continuously comes in unless the faucet is turned off, is that correct? If so you'll need a water valve. That's the part on the back of the machine that the inlet hoses attach to.
Part number: AP3094541
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-19-2009, 08:54 AM
Junior Member
Default
the cold water will not run during cycles unless i turn the water switch off and on, on the wall where hoses are attached. otherwise i hear a hissing sound as if machine is trying to access water. if i go behind the machine and switch the connection off and then on the cold water will run just fine.
  #4 (permalink)
Old 08-19-2009, 09:05 AM
Senior Expert
Default
The hissing sound you're hearing, I'm going to assume is the washers water valve humming/calling, for water.
If you have to turn your faucet/lever on and off to get the cold water to flow, it sounds as though you've got a plumbing problem.
Just to make sure there isn't any blockage between the faucet and the washer, you may want to turn the lever off and check the end of the cold water hose. There should be a filter screen in the end where it attaches to the house. Make sure the filter is clean.
Where the other end attaches to the washer, which is the water valve you have a picture of, there is a screen in the valve. Make sure it is also clean.
__________________
  #5 (permalink)
Old 06-16-2011, 07:20 PM
Junior Member
Bill L is on a distinguished road
Default Dispensing Cold Water is very Slow
Here's my Problem
1. Starting a new load - Temperature is set for Hot/Cold
2. The washing machine will load the hot water just fine and washing begins.
3. After the Hot water has emptied for the wash, the cold water will start to come out. Here's the problem, the cold water is being dispensed as a trickle and takes a very long time to fill the tub.
If the temp is set for cold/cold, the cold water is dispensed as a trickle for both the wash and rinse cycle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 Series Washer - no cold water, weak spin cycle? PHRoberts Washer Repair 3 01-16-2010 04:28 PM
washer low cold water flow jtwestring Washer Repair 1 08-28-2009 07:08 AM
Washer does not dispense cold water Marcia0516 Washer Repair 1 08-01-2009 08:27 AM
washer doesnt have cold water sadiejade99 Washer Repair 2 07-28-2009 09:53 PM
washer won"t run on cold cold water setting jwh4969 Washer Repair 1 12-23-2008 06:41 AM
