Discuss
GE stackable will not agitate but will spin
 in
Washer Repair
Inspected washer found tub will not agitate but spin cycle works fine. Found motor overloading when trying to run in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE stackable will not agitate but will spin
  #1 (permalink)
Old 01-16-2008, 12:10 PM
roger278 roger278 is offline
Junior Member
roger278 is on a distinguished road
Post GE stackable will not agitate but will spin
Model Number: wsm27tcawwb   Brand: GE   Age: 5 - 10 years
Inspected washer found tub will not agitate but spin cycle works fine. Found motor overloading when trying to run in wash cycle. removed belt, motor is spinning in both directions no problem. is there a problem with the transmission? Also having lots of trouble removing transmission shaft from inner tub any suggestions. (Have agitator removed and everything unbolted, just cant pull shaft through tub)
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin or agitate nate Washer Repair 0 11-25-2007 12:44 PM
Washer will spin but not agitate dolpfan217805 Washer Repair 3 11-20-2007 11:44 AM
RCA Washer will not spin or agitate huffmanrq Washer Repair 0 11-18-2007 09:22 AM
washer won't spin or agitate chartman Washer Repair 0 11-12-2007 08:39 PM
Washer won't spin or agitate BH5977 Washer Repair 3 11-03-2007 03:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
