| » will not spin or drain |
Hi.
Take off the front panel and check if the drain pump is running. Check all the drain hoses and the sump. Most likely there is a clogged drain or pump. For further assistance provide complete model number. Thank you. Post the results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
__________________
| Display Modes | |
| Washer will only drain if put on "Drain+Spin" cycle. | Arieleno | Washer Repair | 7 | 11-02-2011 07:03 PM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works | cosmo99 | Washer Repair | 1 | 01-27-2010 11:33 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
