Purchased almost 5 years ago. Been in Storage for last 4 years. Tried to start and after it fills for 2 minutes and drum begins turning each direction a couple times, it stops and gives code FH, then washer drains and shuts off. I read that it was a water supply issue so I checked my hoses and screens and all is good there!
Take off the top and you should find some tech notes that will tell you how to interpret the codes and how to put it into diagnostic mode and test the components.
Having been in storage that long it could just be a number of things, so you are going to have to go through all the tests.
