| » Dryer drying cycle does not turn off |
Model Number: LDE8424ACE Brand: Maytag Age: 1 - 5 years
The dryer itself dries properly, but when the knob is turn on to dry the clothes, it seems to stay in one place and doesn't always shut off. If I turn the knob manually towards the end of the cycle, then it is more likely to automatically turn off. Otherwise, the dryer will just keep on running until I shut it off. Thank you
Quote:
Try running the dryer with the vent hose removed. A slow vent will cause what you're describing. From there you'll need to look at the cycling thermostat. That is the part that tells the timer to advance. It sends a signal to the timer when the proper temp is achieved in the drum. In other words when the element cycles off the timer motor moves a little bit. When it cools down and the element comes back on the timer stops. This action takes place when you're using one of the auto cycles. If you have a slow vent it can cause the high limit thermostat to do the cycling instead of the proper one. You can find a parts breakdown and a wiring diagram at the below link. Model LDE8424ACE
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag Dryer stops in middle of drying cycle | tekatoo | Dryer Repair | 1 | 01-24-2010 07:33 AM |
| Dryer elements cycle off and on making long drying cycles | showmewarrior | Dryer Repair | 1 | 04-19-2009 12:39 PM |
| Dryer stops and starts during entire drying cycle, is this normal? | loric228 | Dryer Repair | 2 | 01-05-2009 09:57 AM |
| Whirlpool Dryer Wii Not Cool Down Or Turn Off In Timed Cycle | Danny Timmons | Dryer Repair | 1 | 10-12-2008 11:21 AM |
| Dryer stopped mid drying cycle and won't start again | scsimpson | Dryer Repair | 2 | 11-25-2007 06:44 PM |
