Discuss
Whirlpool duet HT
 in
Washer Repair
Greetings, My washer has decided to leak a little bit. This started last weekend and it leaks on the front,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool duet HT
  #1 (permalink)
Old 03-22-2012, 09:46 AM
Junior Member
brasilmom1 is on a distinguished road
Default Whirlpool duet HT
Brand: Whirlpool   Age: 1 - 5 years
Greetings,
My washer has decided to leak a little bit. This started last weekend and it leaks on the front, sort of. I first thought it was coming from the door, but further inspection proved me wrong. The water is coming from somewhere on the lower portion of the front. I will try to remove the front panel today, but thought would ask here if this is the end of my machine. I sure hope not.
Thanks. Be well
Miriam
Ads By Google
  #2 (permalink)
Old 03-22-2012, 12:57 PM
Gary/APP Team's Avatar
Expert
Gary/APP Team is on a distinguished road
Default
Hello. The first thing to check is on the glass part of the door , is it clean ? clean it with windex or some other type cleaner , as long as you are sure it is clean , you can also run this thru the unit, Part number: AP4320055
to help, next option would be the door boot bellow, be sure to include the correct model number of your unit in your next post it can be found inside the door usually on the left hand side thank you and good luck !
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-22-2012, 01:42 PM
Junior Member
Default
Thank you Gary for your reply. The glass is clean as I clean it regularly. I think that the door boot may be the issue here. I will check it tonight. Perhaps I will try to find some of the cleaner as well. The model is GHW9400PW4.
Once I check the door boot I will report back.
Thanks again. Be well
Miriam
  #4 (permalink)
Old 03-22-2012, 02:00 PM
Expert
Default
Hello . Thank you the reason I ask you to check the glass is there is one spot right in the center of the bottom of the glass where I have seen it many times just a small amount of hair cause one to leak, any way here is the part # for the boot Part number: AP3597347
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool duet +f28 misterfixall Washer Repair 3 12-13-2011 01:47 PM
wHIRLPOOL DUET muscle car Dryer Repair 6 07-14-2010 02:09 AM
Whirlpool Duet benzlerp Washer Repair 3 03-24-2010 01:39 PM
whirlpool duet moodster Washer Repair 3 07-04-2009 01:38 PM
Whirlpool Duet--really need help NewbySteve Washer Repair 8 07-02-2009 06:37 PM
