Discuss
Won’t agitate in gentle cycle
 in
Washer Repair
Hello, A year and a half ago, I used your forum to determine that the timer on my washer needed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won’t agitate in gentle cycle
  #1 (permalink)
Old 03-21-2012, 12:42 PM
Junior Member
Joyous is on a distinguished road
Question Won’t agitate in gentle cycle
Model Number: LST8244BQ1   Brand: Whirlpool   Age: More than 10 years
Hello,
A year and a half ago, I used your forum to determine that the timer on my washer needed replaced. (Thanks for the help!) I put the new one in and it worked fine until recently.
Once again, I'm having an (intermittent) issue with the agitator. This is an 8 cycle, 2 speed washer. When using normal, heavy or super wash cycles, it agitates fine until it enters the second half which is "soft wash", then 90% of the time the agitation will stop. This of course pertains to the gentle cycle as well. However, it will correctly continue advancing through to the spin and rinse cycles without a problem. Is it possible for the timer to go out again-especially in such a short time span or could this be Transmission related? Any insight you can offer on this will be truly appreciated.
Related Models
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
 LSU182HE Air Conditioner
 LSU240HE Air Conditioner
 LSU242CE Air Conditioner
 LSU242HE Air Conditioner
 LSUC121PMA Air Conditioner
 LSUJ0910CL Air Conditioner
 LSUK1830CL Air Conditioner
 LSUK1830HL Air Conditioner
 LSUK2430CL Air Conditioner
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
Whirlpool LSV7233DZ0
Whirlpool LSV7244AN0
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0 AUTOMATIC WASHER
Whirlpool LSV8244BQ0 AUTOMATIC WASHER
Whirlpool LSV8244BW0 AUTOMATIC WASHER
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Whirlpool LSW9245EQ0 AUTOMATIC WASHER
Whirlpool LSW9245EQ1 AUTOMATIC WASHER
Whirlpool LSW9245EQ2 AUTOMATIC WASHER
Whirlpool LSW9700PQ0 AUTOMATIC WASHER
Whirlpool LSW9700PQ1 AUTOMATIC WASHER
Whirlpool LSW9700PQ2 AUTOMATIC WASHER
Whirlpool LSW9750PW0 AUTOMATIC WASHER
Whirlpool LSW9750PW1 AUTOMATIC WASHER
Whirlpool LSW9750PW2 AUTOMATIC WASHER
Whirlpool LSW9750PW3 AUTOMATIC WASHER
 LT0810C Air Conditioner
 LT0810CR Air Conditioner
 LT1010C Air Conditioner
 LT1010CR Air Conditioner
 LT1030CR Air Conditioner
 LT1030H Air Conditioner
 LT1030HR Air Conditioner
 LT1210C Air Conditioner
 LT1210CR Air Conditioner
 LT1230C Air Conditioner
 LT1230CR Air Conditioner
 LT1230H Air Conditioner
 LT1230HR Air Conditioner
 LT1430CR Air Conditioner
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
  #2 (permalink)
Old 03-22-2012, 04:45 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I don't think this is the transmission. The motor in your machine is a two speed motor and for some reason the slow speed is not kicking in. I would say this is a timer issue if you had not replaced it and actually I still think it is a timer issue because the other possibility is the motor, which fails much less frequently.
The first thing I would do is take off the motor connector and clean the terminals with a good electrical cleaner and the reseat it and make sure the connections are tight. Do the same with the connector at the timer. If that does not fix things you can try replacing the timer or the motor, your pick.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not agitate in Gentle cycle malgase Washer Repair 3 05-09-2011 06:16 PM
Whirlpool washer squealing in regular cycle not gentle cycle cttntal209 Washer Repair 0 12-13-2010 09:11 AM
GE Washer Wont agitate on gentle TommyS Washer Repair 1 11-04-2010 05:22 PM
GE profile will not agitate on gentle cycle laroccad Washer Repair 4 07-28-2009 08:50 PM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
