Discuss
whirlpool washer won't drain with load
 in
Washer Repair
I have a Whirlpool CAre MAster II, 2 speed direct drive washer that won't drain. It seems like the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer won't drain with load
  #1 (permalink)
Old 01-15-2008, 03:23 PM
Junior Member
kimchu is on a distinguished road
Default whirlpool washer won't drain with load
Model Number: LSQ8243HQ0   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool CAre MAster II, 2 speed direct drive washer that won't drain. It seems like the motor won't go into high spin for the water to drain when there the tub is 1/2 full of water (no clothes). When the water level is low, less than 1/3, it goes into high spin and the water drains properly.
Not sure what the problem is to order the right parts.
Thanks.
Kim
Ads By Google
Related Models
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
  #2 (permalink)
Old 01-16-2008, 02:23 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Sounds like either a partial pump clog, or a bad clutch. Pull outer panel and check pump. Post results.
__________________
  #3 (permalink)
Old 01-16-2008, 06:39 AM
Junior Member
Default
Hello,
thanks for the reply.
I pulled out the pump and look at it. It looks ok, no clog. Again, with 1/3 tub of water, motor just slow spins, never spins faster enough to drain out the water. After i manually remove most of the water, the motor can get into high spin and spin out the water. What is the clutch you referred to ?
Is there is switch that activites the motor into high speed that may be faulty ? What is the purpose of the washer capacitor ? Can that cause the motor to not start the high speed ?
Thanks.
Kim
  #4 (permalink)
Old 01-16-2008, 07:43 AM
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default pump
When it goes into spi. Does the water come out of the drain hose at a good flow rate? I'm pretty sure you have a drain issue. Which may be taking out your clutch. but the water still has to drain for it to goo into high speed.
  #5 (permalink)
Old 01-16-2008, 07:51 AM
Junior Member
Default
yes, when it drains with less than approx 1/3 water in tank, the water comes normal rate. I tried it with the pump popped out of the motor, the motor never spins up when there is appro 1/3 tub of water. Is there a way to test the clutch ? Thanks.
  #6 (permalink)
Old 01-16-2008, 08:32 AM
Senior Expert
APP Volunteer
Default ok
When you are testing washer . Does all the water drain out? Then does it spin at a higher speed? Or does the spin start when water level gets to 1/3 level then spins alright or what?
  #7 (permalink)
Old 01-16-2008, 08:42 AM
Junior Member
Default
During normal washing operation, the washer spins but slowly and no water gets spin/drained out. I started to test it by emptying all water and then putting the washer in spin cycle. With no water, it spins normally. I started to manually filled the water up and noticed that at a certain point of filling (approx 1/3) the motor won't go into a full fast spin. There is a couple of clicking sound as if the motor is trying to get into a fast spinning cycle but fails and will spins slowly, During the slow spin, no water drains out.
  #8 (permalink)
Old 01-16-2008, 02:58 PM
Senior Expert
APP Volunteer
Default
You have a bad motor, or a burnt wire somewhere. Does it do this on all cycles?
You also may have bad bearings in the motor, just check for lateral play. If your timer has a metal cover, you might want to pull it off and check for burnt contacts. Also, check your motor centrifical switch for oil contamination. Post results.
__________________
  #9 (permalink)
Old 01-16-2008, 03:24 PM
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Thumbs up whirlpool washer won't drain with load
This is a neautral drain machine. Normally, after the agitatation cycle, before spinning, the machine should drain, w/o spinning, fot 2 min. Do a load of wash and observe the cycle. After washing for at least 8 min.(you need to warm up the transmission) see if it pauses for a few seconds then drains for 2 min. without trying to spin. Be sure it's not suds locking(too much detergent) Let us know..wrench
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front Load Washer Won't Drain scottbreen Washer Repair 35 01-27-2013 01:31 PM
Samsung Top Load Washer won't drain sometimes AllanN Washer Repair 0 01-02-2010 02:46 PM
Front load washer will not rinse/drain or spin out haroldlm Washer Repair 2 12-11-2009 06:08 AM
1993 GE top-load washer- fills w/water; won't agitate or drain clyng Washer Repair 2 08-13-2009 06:32 PM
front load washer is not drain and spin keithzhao Washer Repair 9 12-04-2008 07:27 AM
