Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Kenmore Washer top load 70 Series (http://forum.appliancepartspros.com/washer-repair/44389-kenmore-washer-top-load-70-series.html)
gmcanazon 08-16-2009 10:31 AM
I had a leak coming from the top of the washer. Looks like the basket is leaning to the front right allowing the water as it comes in to overflow the plastic on the back side. The springs look like they may need to be replaced. I moved the springs to new positions. Now I have this metal trianglular brake that is loose and I don't know why or if it is supposed to be loose. I didn't take any screws out of it. When I set it upright and move the basket back and forth it seems like something is out of place. Help!
sidfink43 08-17-2009 05:18 PM
Buy a new set of springs (they are inexpensive) and replace them in the exact same position as the old ones.
Here is a site which will show you how to get the "triangular" piece back i place.
http://www.applianceaid.com/suspention.html
That should fix things up unless you have other problems.
