Drum leaking
I have a stackable washer/dryer. It is leaking at a couple of bolts that holds the drum together. I have tightened the bolts and it has slowed the leak. Is there a gasket that needs to be replaced?
Thanks, Bob |
Hello . Here is the gasket Part number: AP3212518
that goes in between the two outer tubs. Model 417.40042990 |
| All times are GMT -7. The time now is 08:58 AM. |
