hello there, I have a kenmore top loaded washing machine that gives me the code: F1 when I push the start botton, any suggetions? thank you so much.
Hi Hector, Check the pressure hose connection from the tub to the machine/motor control board. If there is nothing wrong, replace the machine/motor control board. - The machine/motor control board Part number: AP4360738
Gene. P.S. The disassemble procedure described in the tech sheet which is located under the cabinet top.
