Discuss
washer dont drain before it goes into spin
 in
Washer Repair
My whirlpool washer does not drain before spin cycle I get water from the bottom all over the floor. Any
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer dont drain before it goes into spin
  #1 (permalink)
Old 08-16-2009, 07:29 AM
Junior Member
Ken Smith is on a distinguished road
Default washer dont drain before it goes into spin
Brand: Whirlpool   Age: 5 - 10 years
My whirlpool washer does not drain before spin cycle I get water from the bottom all over the floor. Any suggestioins.
Thank You
Ads By Google
  #2 (permalink)
Old 08-17-2009, 10:36 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Ken
Please post a full model number. I assume that the water on the floor is from it spinning with water in it and not a leak. Is that correct?
Also, have you check the drain and drain hoses to see that they are not obstructed?
__________________
  #3 (permalink)
Old 08-17-2009, 11:03 AM
Junior Member
Default
My model is SM 8280869 Whirlpool 5 cycles 4 speed combination, This started all at once never did this in the past. I have not checked the hose to see if it was obstructed. Thank you for the info, any thing else it might be.ThanksKen
  #4 (permalink)
Old 08-17-2009, 01:34 PM
Senior Expert
APP Volunteer
Default
Hi Ken
Your model number does not come up, did you provide the serial number instead? Is this a U. S. model?
Let us know if you need more help, and if so, repost the model number is what you provided is not correct.
__________________
  #5 (permalink)
Old 08-17-2009, 04:13 PM
Junior Member
Default
That is all I have, I dont have a manual, the number I gave is the only number I could find. I look up & down I dont see no model #, where should I look else.
Thank you
Ken
  #6 (permalink)
Old 08-17-2009, 04:15 PM
Senior Expert
APP Volunteer
Default
If this is a top loader, look on the rim after you lift the lid; if it is a front loader look inside the door.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
washer agitates,dont spin fourjaxson Washer Repair 9 08-05-2008 09:13 PM
Washer won't drain or spin Ruby Washer Repair 1 07-28-2008 01:51 PM
agitates but dont spin while agitating acmesa Washer Repair 1 07-21-2008 09:56 PM
my washer will not drain or spin pmiller678 Washer Repair 1 02-28-2008 12:52 PM
